Beam Design - Top Chord
Design Span (L): 7.71 ft.
Clear Span: 7.42 ft.
Total Span: 8.00 ft.
Bearing (lb): 3.5 in.
Live Load: 50 plf
Dead Load: 25 plf
Selfweight: 15.1 lbs
Dist. Selfweight: 1.96 plf
Total Weight: 15.7 lbs
Beam Design Nate Bennett 151 Tandberg Trail NLB-050620
5/6/2020 1
5/6/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (92.50 + 3.5)] x (12 in./ft.)3 = 0.46 ft3
Volumespan = N[A x L] = 1 x [8.25 x 92.50] x (12 in./ft.)3 = 0.44 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.46 = 15.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.44 = 15.1 lbs
50 plf
25 plf
ws = 1.96 plf
7.71 ft.
7.42 ft.
307.83 lbs
307.83 lbs
5/6/2020 3
Fbx' = (900)(1.15)(1)(1)(1)(1.3)(1)(1.15) = 1547.3 psi
fb = = 906.9 psi
 fb = 906.9 psi < Fbx' = 1547.3 psi  (CSI = 0.59)   ➜  OK
5/6/2020 4
fv* = = 47.51 psi
 fv* = 47.51 psi < Fvx' = 207.00 psi  (CSI = 0.23)   ➜  OK
fv = = 53.93 psi
 fv = 53.93 psi < Fvx' = 207.00 psi  (CSI = 0.26)   ➜  OK
5/6/2020 5
ΔLL = = 0.12 in.
(L/d)LL = 92.50 / 0.12 = 775
 ΔLL = 0.12 in = L/775 < L/360   ➜  OK
ΔTL = = 0.18 in.
(L/d)TL = 92.50 / 0.18 = 504
 ΔTL = 0.18 in = L/504 < L/240   ➜  OK
fc⊥ = = 58.6 psi
 fc⊥ = 58.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.09)   ➜  OK
5/6/2020 6
