Design Span (L): 7.86 ft.
Clear Span: 7.61 ft.
Total Span: 8.11 ft.
Live Load: 40 plf
Dead Load: 300 plf
Selfweight: 31.5 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 32.5 lbs
Beam Design 2020A83
5/4/2020 1
Beam Design 2020A83
5/4/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (94.26 + 3)] x (12 in./ft.)3 = 0.95 ft3
Volumespan = N[A x L] = 1 x [16.88 x 94.26] x (12 in./ft.)3 = 0.92 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.95 = 32.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.92 = 31.5 lbs
40 plf
300 plf
ws = 4.01 plf
7.86 ft.
7.61 ft.
8.11 ft.
1394.09 lbs
1394.09 lbs
Beam Design 2020A83
5/4/2020 3
fb = = 1006.3 psi
 fb = 1006.3 psi < Fbx' = 1035.0 psi  (CSI = 0.97)   ➜  OK
Beam Design 2020A83
5/4/2020 4
fv* = = 91.43 psi
 fv* = 91.43 psi < Fvx' = 207.00 psi  (CSI = 0.44)   ➜  OK
fv = = 120.10 psi
 fv = 120.10 psi < Fvx' = 207.00 psi  (CSI = 0.58)   ➜  OK
Beam Design 2020A83
5/4/2020 5
ΔLL = = 0.01 in.
(L/d)LL = 94.26 / 0.01 = 7834
 ΔLL = 0.01 in = L/7834 < L/360   ➜  OK
ΔTL = = 0.10 in.
(L/d)TL = 94.26 / 0.10 = 911
 ΔTL = 0.10 in = L/911 < L/240   ➜  OK
fc⊥ = = 309.8 psi
 fc⊥ = 309.8 psi < Fc⊥x' = 625.00 psi  (CSI = 0.50)   ➜  OK
Beam Design 2020A83
5/4/2020 6
