Design Span (L): 16.00 ft.
Clear Span: 15.75 ft.
Total Span: 16.25 ft.
Live Load: 10 plf
Dead Load: 33 plf
Selfweight: 64.1 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 65.1 lbs
Beam Design 2020A81
4/28/2020 1
Beam Design 2020A81
4/28/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (192.00 + 3)] x (12 in./ft.)3 = 1.90 ft3
Volumespan = N[A x L] = 1 x [16.88 x 192.00] x (12 in./ft.)3 = 1.88 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.90 = 65.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.88 = 64.1 lbs
10 plf
33 plf
ws = 4.01 plf
15.75 ft.
16.25 ft.
381.94 lbs
381.94 lbs
Beam Design 2020A81
4/28/2020 3
Fbx' = (900)(1.15)(1)(0.8)(1)(1)(1)(1) = 828.0 psi
fb = = 570.5 psi
 fb = 570.5 psi < Fbx' = 828.0 psi  (CSI = 0.69)   ➜  OK
Beam Design 2020A81
4/28/2020 4
Fvx' = (180)(1.15)(1)(0.8)(1) = 165.60 psi
fv* = = 29.51 psi
 fv* = 29.51 psi < Fvx' = 165.60 psi  (CSI = 0.18)   ➜  OK
fv = = 33.43 psi
 fv = 33.43 psi < Fvx' = 165.60 psi  (CSI = 0.20)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1600000(1)(0.9)(1) = 1440000 psi
Beam Design 2020A81
4/28/2020 5
ΔLL = = 0.06 in.
(L/d)LL = 192.00 / 0.06 = 3337
 ΔLL = 0.06 in = L/3337 < L/180   ➜  OK
ΔTL = = 0.27 in.
(L/d)TL = 192.00 / 0.27 = 710
 ΔTL = 0.27 in = L/710 < L/120   ➜  OK
fc⊥ = = 84.9 psi
 fc⊥ = 84.9 psi < Fc⊥x' = 500.00 psi  (CSI = 0.17)   ➜  OK
Beam Design 2020A81
4/28/2020 6
