Size: 5.5 x 18
Design Span (L): 17.88 ft.
Clear Span: 17.50 ft.
Total Span: 18.25 ft.
Bearing (lb): 4.5 in.
Live Load: 943 plf
Dead Load: 408 plf
Selfweight: 414.9 lbs
Dist. Selfweight: 23.21 plf
Total Weight: 423.6 lbs
CV Volume Factor 0.969b - - - - -
Beam Design 2020A80
4/27/2020 1
d = 18.000 in.
Beam Design 2020A80
4/27/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [99.00 x (214.50 + 4.5)] x (12 in./ft.)3 = 12.55 ft3
Volumespan = N[A x L] = 1 x [99.00 x 214.50] x (12 in./ft.)3 = 12.29 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 12.55 = 423.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 12.29 = 414.9 lbs
943 plf
408 plf
  ws = 23.21 plf
17.88 ft.
17.50 ft.
18.25 ft.
12539.67 lbs
12539.67 lbs
Beam Design 2020A80
4/27/2020 3
CV = = 0.969
CV = 0.969 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.969) = 2674.4 psi
fb = = 2217.6 psi
 fb = 2217.6 psi < Fbx' = 2674.4 psi  (CSI = 0.83)   ➜  OK
Beam Design 2020A80
4/27/2020 4
fv* = = 154.86 psi
 fv* = 154.86 psi < Fvx' = 304.75 psi  (CSI = 0.51)   ➜  OK
fv = = 186.09 psi
 fv = 186.09 psi < Fvx' = 304.75 psi  (CSI = 0.61)   ➜  OK
Beam Design 2020A80
4/27/2020 5
ΔLL = = 0.45 in.
(L/d)LL = 214.50 / 0.45 = 476
 ΔLL = 0.45 in = L/476 < L/360   ➜  OK
ΔTL = = 0.66 in.
(L/d)TL = 214.50 / 0.66 = 327
 ΔTL = 0.66 in = L/327 < L/240   ➜  OK
Ab = b x lb = 5.5 x 4.5 = 24.75 in2
fc⊥ = = 506.7 psi
 fc⊥ = 506.7 psi < Fc⊥x' = 650.00 psi  (CSI = 0.78)   ➜  OK
Beam Design 2020A80
4/27/2020 6
