Beam Design - J
Size: 5.125 x 10.5
Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Live Load: 42 plf
Dead Load: 25 plf
Selfweight: 173.5 lbs
Dist. Selfweight: 12.62 plf
Total Weight: 176.6 lbs
Beam Design 3729 S Pinal Dr 2020A79
4/27/2020 1
b = 5.125 in.
d = 10.500 in.
A = 5.125 x 10.500 = 53.81 in.2
Sx = (5.125)(10.500)2/6 = 94.17 in.3
Sy = (5.125)2(10.500)/6 = 45.96 in.3
Ix = (5.125)(10.500)3/12 = 494.40 in.4
Iy = (5.125)3(10.500)/12 = 117.78 in.4
4/27/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [53.81 x (165.00 + 3)] x (12 in./ft.)3 = 5.23 ft3
Volumespan = N[A x L] = 1 x [53.81 x 165.00] x (12 in./ft.)3 = 5.14 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.23 = 176.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.14 = 173.5 lbs
Distributed Self Weight (ws) = = 12.62 plf
42 plf
25 plf
  ws = 12.62 plf
13.75 ft.
13.50 ft.
557.32 lbs
557.32 lbs
4/27/2020 3
fb = = 239.8 psi
 fb = 239.8 psi < Fbx' = 2760.0 psi  (CSI = 0.09)   ➜  OK
4/27/2020 4
fv* = = 13.32 psi
 fv* = 13.32 psi < Fvx' = 304.75 psi  (CSI = 0.04)   ➜  OK
fv = = 15.26 psi
 fv = 15.26 psi < Fvx' = 304.75 psi  (CSI = 0.05)   ➜  OK
4/27/2020 5
ΔLL = = 0.04 in.
(L/d)LL = 165.00 / 0.04 = 4347
 ΔLL = 0.04 in = L/4347 < L/180   ➜  OK
ΔTL = = 0.07 in.
(L/d)TL = 165.00 / 0.07 = 2293
 ΔTL = 0.07 in = L/2293 < L/120   ➜  OK
fc⊥ = = 36.2 psi
 fc⊥ = 36.2 psi < Fc⊥x' = 650.00 psi  (CSI = 0.06)   ➜  OK
4/27/2020 6
