Size: 5.125 x 10.5
Design Span (L): 22.75 ft.
Clear Span: 22.50 ft.
Total Span: 23.00 ft.
Live Load: 42 plf
Dead Load: 25 plf
Selfweight: 287.0 lbs
Dist. Selfweight: 12.62 plf
Total Weight: 290.2 lbs
Beam Design J 3729 S Pinal Dr 2020A75
4/27/2020 1
b = 5.125 in.
d = 10.500 in.
A = 5.125 x 10.500 = 53.81 in.2
Sx = (5.125)(10.500)2/6 = 94.17 in.3
Sy = (5.125)2(10.500)/6 = 45.96 in.3
Ix = (5.125)(10.500)3/12 = 494.40 in.4
Iy = (5.125)3(10.500)/12 = 117.78 in.4
4/27/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [53.81 x (273.00 + 3)] x (12 in./ft.)3 = 8.60 ft3
Volumespan = N[A x L] = 1 x [53.81 x 273.00] x (12 in./ft.)3 = 8.50 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 8.60 = 290.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 8.50 = 287.0 lbs
Distributed Self Weight (ws) = = 12.62 plf
42 plf
25 plf
  ws = 12.62 plf
22.75 ft.
22.50 ft.
23.00 ft.
915.59 lbs
915.59 lbs
4/27/2020 3
fb = = 656.4 psi
 fb = 656.4 psi < Fbx' = 2760.0 psi  (CSI = 0.24)   ➜  OK
4/27/2020 4
fv* = = 23.30 psi
 fv* = 23.30 psi < Fvx' = 304.75 psi  (CSI = 0.08)   ➜  OK
fv = = 25.24 psi
 fv = 25.24 psi < Fvx' = 304.75 psi  (CSI = 0.08)   ➜  OK
4/27/2020 5
ΔLL = = 0.28 in.
(L/d)LL = 273.00 / 0.28 = 960
 ΔLL = 0.28 in = L/960 < L/180   ➜  OK
ΔTL = = 0.54 in.
(L/d)TL = 273.00 / 0.54 = 506
 ΔTL = 0.54 in = L/506 < L/120   ➜  OK
fc⊥ = = 59.6 psi
 fc⊥ = 59.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.09)   ➜  OK
4/27/2020 6
