Design Span (L): 11.71 ft.
Clear Span: 11.42 ft.
Bearing (lb): 3.5 in.
Live Load: 20 plf
Dead Load: 10 plf
Selfweight: 33.0 lbs
Dist. Selfweight: 2.82 plf
Total Weight: 33.8 lbs
CL Beam Stability Factor 0.985 - - - - -
Beam Design 2020A70
4/24/2020 1
Beam Design 2020A70
4/24/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (140.50 + 3.5)] x (12 in./ft.)3 = 0.91 ft3
Volumespan = N[A x L] = 1 x [10.88 x 140.50] x (12 in./ft.)3 = 0.88 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.91 = 33.8 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.88 = 33.0 lbs
Distributed Self Weight (ws) = = 2.82 plf
20 plf
10 plf
ws = 2.82 plf
11.71 ft.
11.42 ft.
196.91 lbs
196.91 lbs
Beam Design 2020A70
4/24/2020 3
lu/d = = 3.31
Rb = = 12.62
 Rb = 12.62 < 50   ➜  OK
Beam Design 2020A70
4/24/2020 4
FbE = = 3841.65 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (925)(1.00)(1)(1)(1)(1)(1) = 925.00 psi
CL =   = 0.985
Fbx' = (925)(1.00)(1)(1)(0.985)(1)(1)(1) = 910.8 psi
fb = = 513.5 psi
 fb = 513.5 psi < Fbx' = 910.8 psi  (CSI = 0.56)   ➜  OK
fv* = = 23.76 psi
 fv* = 23.76 psi < Fvx' = 175.00 psi  (CSI = 0.14)   ➜  OK
fv = = 26.50 psi
 fv = 26.50 psi < Fvx' = 175.00 psi  (CSI = 0.15)   ➜  OK
Beam Design 2020A70
4/24/2020 5
ΔLL = = 0.13 in.
(L/d)LL = 140.50 / 0.13 = 1108
 ΔLL = 0.13 in = L/1108 < L/240   ➜  OK
ΔTL = = 0.21 in.
(L/d)TL = 140.50 / 0.21 = 675
 ΔTL = 0.21 in = L/675 < L/180   ➜  OK
fc⊥ = = 37.5 psi
 fc⊥ = 37.5 psi < Fc⊥x' = 565.00 psi  (CSI = 0.07)   ➜  OK
Beam Design 2020A70
4/24/2020 6
