Grade: SPF No.3
Design Span (L): 14.00 ft.
Clear Span: 13.75 ft.
Total Span: 14.25 ft.
Live Load: 53.33 plf
Dead Load: 13.33 plf
Selfweight: 78.5 lbs
Dist. Selfweight: 5.61 plf
Total Weight: 79.9 lbs
Beam Design 2020A58
4/8/2020 1
SPF No.3 500 250 135 425 650 1200000 440000 0.42
Beam Design 2020A58
4/8/2020 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (168.00 + 3)] x (12 in./ft.)3 = 2.75 ft3
Volumespan = N[A x L] = 2 x [13.88 x 168.00] x (12 in./ft.)3 = 2.70 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 2.75 = 79.9 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 2.70 = 78.5 lbs
53.33 plf
13.33 plf
ws = 5.61 plf
13.75 ft.
14.25 ft.
514.91 lbs
514.91 lbs
Beam Design 2020A58
4/8/2020 3
Fbx' = (500)(1.00)(1)(1)(1)(1.1)(1)(1) = 550.0 psi
fb = = 496.6 psi
 fb = 496.6 psi < Fbx' = 550.0 psi  (CSI = 0.90)   ➜  OK
Beam Design 2020A58
4/8/2020 4
fv* = = 24.33 psi
 fv* = 24.33 psi < Fvx' = 135.00 psi  (CSI = 0.18)   ➜  OK
fv = = 27.34 psi
 fv = 27.34 psi < Fvx' = 135.00 psi  (CSI = 0.20)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1200000(1)(1)(1) = 1200000 psi
Beam Design 2020A58
4/8/2020 5
ΔLL = = 0.19 in.
(L/d)LL = 168.00 / 0.19 = 865
 ΔLL = 0.19 in = L/865 < L/360   ➜  OK
ΔTL = = 0.26 in.
(L/d)TL = 168.00 / 0.26 = 639
 ΔTL = 0.26 in = L/639 < L/240   ➜  OK
fc⊥ = = 57.2 psi
 fc⊥ = 57.2 psi < Fc⊥x' = 425.00 psi  (CSI = 0.13)   ➜  OK
Beam Design 2020A58
4/8/2020 6
