Grade: SP SS
Design Span (L): 7.81 ft.
Clear Span: 7.63 ft.
Total Span: 8.00 ft.
Bearing (lb): 2.25 in.
Live Load: 700 plf
Dead Load: 200 plf
Selfweight: 68.4 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 70.0 lbs
Lateral Support: 4' o/c
CL Beam Stability Factor 0.981 - - - - -
Beam Design 2020A55
4/2/2020 1
SP SS 1600 1100 175 565 1650 1800000 660000 0.55
Beam Design 2020A55
4/2/2020 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (93.76 + 2.25)] x (12 in./ft.)3 = 1.88 ft3
Volumespan = N[A x L] = 2 x [16.88 x 93.76] x (12 in./ft.)3 = 1.83 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.88 = 70.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.83 = 68.4 lbs
700 plf
200 plf
ws = 8.75 plf
7.81 ft.
7.63 ft.
3635.22 lbs
3635.22 lbs
Beam Design 2020A55
4/2/2020 3
lu = Unbraced Length = 4 ft.
lu/d = = 4.27
Rb = = 11.12
 Rb = 11.12 < 50   ➜  OK
Beam Design 2020A55
4/2/2020 4
Eminy' = Eminy(CM)(Ct)(Ci) = 660000(1)(1)(1) = 660000 psi
FbE = = 6407.77 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1600)(1.15)(1)(1)(1)(1)(1) = 1840.00 psi
CL =   = 0.981
Fbx' = (1600)(1.15)(1)(1)(0.981)(1)(1)(1) = 1804.6 psi
fb = = 1314.9 psi
 fb = 1314.9 psi < Fbx' = 1804.6 psi  (CSI = 0.73)   ➜  OK
fv* = = 119.91 psi
 fv* = 119.91 psi < Fvx' = 201.25 psi  (CSI = 0.60)   ➜  OK
fv = = 157.78 psi
 fv = 157.78 psi < Fvx' = 201.25 psi  (CSI = 0.78)   ➜  OK
Beam Design 2020A55
4/2/2020 5
ΔLL = = 0.09 in.
(L/d)LL = 93.76 / 0.09 = 1024
 ΔLL = 0.09 in = L/1024 < L/240   ➜  OK
ΔTL = = 0.12 in.
(L/d)TL = 93.76 / 0.12 = 788
 ΔTL = 0.12 in = L/788 < L/180   ➜  OK
Ab = b x lb = 1.5 x 2.25 = 3.38 in2
fc⊥ = = 538.6 psi
 fc⊥ = 538.6 psi < Fc⊥x' = 565.00 psi  (CSI = 0.95)   ➜  OK
Beam Design 2020A55
4/2/2020 6
