Selfweight: 38.7 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 39.5 lbs
Beam Design 2020A51
3/22/2020 1
Beam Design 2020A51
3/22/2020 2
ws = 3.30 plf
1069.77 lbs
1069.77 lbs
Beam Design 2020A51
3/22/2020 3
fb = = 1726.2 psi
Beam Design 2020A51
3/22/2020 4
fv* = = 98.38 psi
fv = = 113.24 psi
Beam Design 2020A51
3/22/2020 5
ΔLL = = 0.27 in.
(L/d)LL = 141.00 / 0.27 = 520
 ΔLL = 0.27 in = L/520 < L/180   ➜  OK
ΔTL = = 0.48 in.
(L/d)TL = 141.00 / 0.48 = 292
 ΔTL = 0.48 in = L/292 < L/120   ➜  OK
fc⊥ = = 237.7 psi
Beam Design 2020A51
3/22/2020 6
