Grade: 24F-V3 1.8E SP/SP
Size: 3.5 x 9.625
Design Span (L): 14.75 ft.
Clear Span: 14.50 ft.
Total Span: 15.00 ft.
Live Load: 1000 lbs
Dead Load: 800 lbs
Selfweight: 127.3 lbs
Dist. Selfweight: 8.63 plf
Total Weight: 129.4 lbs
Lateral Support: 4' o/c
CL Beam Stability Factor 0.987 - - - - -
Beam Design 2020A44
3/12/2020 1
d = 9.625 in.
A = 3.500 x 9.625 = 33.69 in.2
Sx = (3.500)(9.625)2/6 = 54.04 in.3
Sy = (3.500)2(9.625)/6 = 19.65 in.3
Ix = (3.500)(9.625)3/12 = 260.07 in.4
Iy = (3.500)3(9.625)/12 = 34.39 in.4
Beam Design 2020A44
3/12/2020 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [33.69 x (177.00 + 3)] x (12 in./ft.)3 = 3.51 ft3
Volumespan = N[A x L] = 1 x [33.69 x 177.00] x (12 in./ft.)3 = 3.45 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 3.51 = 129.4 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 3.45 = 127.3 lbs
Distributed Self Weight (ws) = = 8.63 plf
1000 lbs
800 lbs
  ws = 8.63 plf
14.75 ft.
14.50 ft.
15.00 ft.
964.72 lbs
964.72 lbs
Beam Design 2020A44
3/12/2020 3
lu = Unbraced Length = 4 ft.
lu/d = = 4.99
Rb = = 8.81
 Rb = 8.81 < 50   ➜  OK
Beam Design 2020A44
3/12/2020 4
FbE = = 13128.86 psi
CL =   = 0.987
CL = 0.987 < CV = 1.0
Fbx' = (2400)(1.15)(1)(1)(0.987) = 2724.3 psi
fb = = 1526.0 psi
 fb = 1526.0 psi < Fbx' = 2724.3 psi  (CSI = 0.56)   ➜  OK
fv* = = 42.60 psi
Beam Design 2020A44
3/12/2020 5
 fv* = 42.60 psi < Fvx' = 345.00 psi  (CSI = 0.12)   ➜  OK
fv = = 42.91 psi
 fv = 42.91 psi < Fvx' = 345.00 psi  (CSI = 0.12)   ➜  OK
ΔLL =   =   = 0.25 in.
(L/d)LL = 177.00 / 0.25 = 717
 ΔLL = 0.25 in = L/717 < L/360   ➜  OK
ΔTL =   =   = 0.46 in.
(L/d)TL = 177.00 / 0.46 = 382
 ΔTL = 0.46 in = L/382 < L/240   ➜  OK
Beam Design 2020A44
3/12/2020 6
fc⊥ = = 91.9 psi
 fc⊥ = 91.9 psi < Fc⊥x' = 740.00 psi  (CSI = 0.12)   ➜  OK
Beam Design 2020A44
3/12/2020 7
