Size: 3.5 x 13.5
Design Span (L): 15.00 ft.
Clear Span: 14.50 ft.
Total Span: 15.50 ft.
Live Load: 1000 lbs
Dead Load: 800 lbs
Selfweight: 166.2 lbs
Dist. Selfweight: 11.08 plf
Total Weight: 171.7 lbs
Beam Design 2020A42
3/11/2020 1
d = 13.500 in.
A = 3.500 x 13.500 = 47.25 in.2
Sx = (3.500)(13.500)2/6 = 106.31 in.3
Sy = (3.500)2(13.500)/6 = 27.56 in.3
Ix = (3.500)(13.500)3/12 = 717.61 in.4
Iy = (3.500)3(13.500)/12 = 48.23 in.4
Beam Design 2020A42
3/11/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [47.25 x (180.00 + 6)] x (12 in./ft.)3 = 5.09 ft3
Volumespan = N[A x L] = 1 x [47.25 x 180.00] x (12 in./ft.)3 = 4.92 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.09 = 171.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 4.92 = 166.2 lbs
Distributed Self Weight (ws) = = 11.08 plf
1000 lbs
800 lbs
  ws = 11.08 plf
15.00 ft.
14.50 ft.
15.50 ft.
985.85 lbs
985.85 lbs
Beam Design 2020A42
3/11/2020 3
fb = = 797.1 psi
 fb = 797.1 psi < Fbx' = 2760.0 psi  (CSI = 0.29)   ➜  OK
Beam Design 2020A42
3/11/2020 4
fv* = = 30.81 psi
 fv* = 30.81 psi < Fvx' = 304.75 psi  (CSI = 0.10)   ➜  OK
fv = = 31.21 psi
 fv = 31.21 psi < Fvx' = 304.75 psi  (CSI = 0.10)   ➜  OK
Beam Design 2020A42
3/11/2020 5
ΔLL =   =   = 0.09 in.
(L/d)LL = 180.00 / 0.09 = 1914
 ΔLL = 0.09 in = L/1914 < L/180   ➜  OK
ΔTL =   =   = 0.18 in.
(L/d)TL = 180.00 / 0.18 = 1005
 ΔTL = 0.18 in = L/1005 < L/120   ➜  OK
fc⊥ = = 46.9 psi
 fc⊥ = 46.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.07)   ➜  OK
Beam Design 2020A42
3/11/2020 6
