Grade: SP No.1
Size: 2 x 4
Design Span (L): 2.25 ft.
Clear Span: 2.00 ft.
Total Span: 2.50 ft.
Live Load: 1086 lbs
Dead Load: 466 lbs
Selfweight: 6.1 lbs
Dist. Selfweight: 2.72 plf
Total Weight: 6.8 lbs
Beam Design 2020A39
3/2/2020 1
d = 3.500 in.
A = 1.500 x 3.500 = 5.25 in.2
SP No.1 1500 1000 175 565 1650 1600000 580000 0.55
Beam Design 2020A39
3/2/2020 2
Volumetotal = N[A x (L + lb)] = 2 x [5.25 x (27.00 + 3)] x (12 in./ft.)3 = 0.18 ft3
Volumespan = N[A x L] = 2 x [5.25 x 27.00] x (12 in./ft.)3 = 0.16 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.18 = 6.8 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.16 = 6.1 lbs
Distributed Self Weight (ws) = = 2.72 plf
1086 lbs
466 lbs
ws = 2.72 plf
2.25 ft.
2.00 ft.
2.50 ft.
779.40 lbs
779.40 lbs
Beam Design 2020A39
3/2/2020 3
Fbx' = (1500)(1.15)(1)(1)(1)(1)(1)(1) = 1725.0 psi
fb = = 1713.7 psi
 fb = 1713.7 psi < Fbx' = 1725.0 psi  (CSI = 0.99)   ➜  OK
Beam Design 2020A39
3/2/2020 4
fv* = = 111.18 psi
 fv* = 111.18 psi < Fvx' = 201.25 psi  (CSI = 0.55)   ➜  OK
fv = = 111.29 psi
 fv = 111.29 psi < Fvx' = 201.25 psi  (CSI = 0.55)   ➜  OK
Beam Design 2020A39
3/2/2020 5
ΔLL =   =   = 0.03 in.
(L/d)LL = 27.00 / 0.03 = 1040
 ΔLL = 0.03 in = L/1040 < L/240   ➜  OK
ΔTL =   =   = 0.04 in.
(L/d)TL = 27.00 / 0.04 = 726
 ΔTL = 0.04 in = L/726 < L/180   ➜  OK
fc⊥ = = 86.6 psi
 fc⊥ = 86.6 psi < Fc⊥x' = 565.00 psi  (CSI = 0.15)   ➜  OK
Beam Design 2020A39
3/2/2020 6
