Grade: SPF No.2
Selfweight: 77.5 lbs
Dist. Selfweight: 6.59 plf
Total Weight: 79.1 lbs
Beam Design 2020A37
3/2/2020 1
Beam Design 2020A37
3/2/2020 2
Volumetotal = N[A x (L + lb)] = 3 x [10.88 x (141.00 + 3)] x (12 in./ft.)3 = 2.72 ft3
Volumespan = N[A x L] = 3 x [10.88 x 141.00] x (12 in./ft.)3 = 2.66 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 2.72 = 79.1 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 2.66 = 77.5 lbs
ws = 6.59 plf
1089.55 lbs
1089.55 lbs
Beam Design 2020A37
3/2/2020 3
Fbx' = (875)(1.15)(1)(1)(1)(1.2)(1)(1) = 1207.5 psi
fb = = 954.0 psi
 fb = 954.0 psi < Fbx' = 1207.5 psi  (CSI = 0.79)   ➜  OK
Beam Design 2020A37
3/2/2020 4
fv* = = 44.01 psi
 fv* = 44.01 psi < Fvx' = 155.25 psi  (CSI = 0.28)   ➜  OK
fv = = 49.05 psi
 fv = 49.05 psi < Fvx' = 155.25 psi  (CSI = 0.32)   ➜  OK
Beam Design 2020A37
3/2/2020 5
ΔLL = = 0.21 in.
(L/d)LL = 141.00 / 0.21 = 658
 ΔLL = 0.21 in = L/658 < L/240   ➜  OK
ΔTL = = 0.39 in.
(L/d)TL = 141.00 / 0.39 = 362
 ΔTL = 0.39 in = L/362 < L/180   ➜  OK
fc⊥ = = 80.7 psi
 fc⊥ = 80.7 psi < Fc⊥x' = 425.00 psi  (CSI = 0.19)   ➜  OK
Beam Design 2020A37
3/2/2020 6
