Grade: SPF No.2
Size: 2 x 4
Design Span (L): 6.25 ft.
Clear Span: 6.00 ft.
Total Span: 6.50 ft.
Live Load: 123 plf
Dead Load: 25 plf
Selfweight: 13.3 lbs
Dist. Selfweight: 2.12 plf
Total Weight: 13.8 lbs
Beam Design 2020A36
3/2/2020 1
d = 3.500 in.
A = 1.500 x 3.500 = 5.25 in.2
Beam Design 2020A36
3/2/2020 2
Volumetotal = N[A x (L + lb)] = 2 x [5.25 x (75.00 + 3)] x (12 in./ft.)3 = 0.47 ft3
Volumespan = N[A x L] = 2 x [5.25 x 75.00] x (12 in./ft.)3 = 0.46 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.47 = 13.8 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.46 = 13.3 lbs
Distributed Self Weight (ws) = = 2.12 plf
123 plf
25 plf
ws = 2.12 plf
6.25 ft.
6.50 ft.
487.90 lbs
487.90 lbs
Beam Design 2020A36
3/2/2020 3
Fbx' = (875)(1.15)(1)(1)(1)(1.5)(1)(1) = 1509.4 psi
fb = = 1436.1 psi
 fb = 1436.1 psi < Fbx' = 1509.4 psi  (CSI = 0.95)   ➜  OK
Beam Design 2020A36
3/2/2020 4
fv* = = 60.76 psi
 fv* = 60.76 psi < Fvx' = 155.25 psi  (CSI = 0.39)   ➜  OK
fv = = 67.02 psi
 fv = 67.02 psi < Fvx' = 155.25 psi  (CSI = 0.43)   ➜  OK
Beam Design 2020A36
3/2/2020 5
ΔLL = = 0.28 in.
(L/d)LL = 75.00 / 0.28 = 267
 ΔLL = 0.28 in = L/267 < L/240   ➜  OK
ΔTL = = 0.34 in.
(L/d)TL = 75.00 / 0.34 = 218
 ΔTL = 0.34 in = L/218 < L/180   ➜  OK
fc⊥ = = 54.2 psi
 fc⊥ = 54.2 psi < Fc⊥x' = 425.00 psi  (CSI = 0.13)   ➜  OK
Beam Design 2020A36
3/2/2020 6
