Grade: SPF SS
Selfweight: 51.6 lbs
Dist. Selfweight: 4.39 plf
Total Weight: 52.7 lbs
Beam Design 2020A34
3/2/2020 1
Beam Design 2020A34
3/2/2020 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (141.00 + 3)] x (12 in./ft.)3 = 1.81 ft3
Volumespan = N[A x L] = 2 x [10.88 x 141.00] x (12 in./ft.)3 = 1.77 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.81 = 52.7 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.77 = 51.6 lbs
ws = 4.39 plf
1076.37 lbs
1076.37 lbs
Beam Design 2020A34
3/2/2020 3
Fbx' = (1250)(1.15)(1)(1)(1)(1.2)(1)(1) = 1725.0 psi
fb = = 1413.6 psi
 fb = 1413.6 psi < Fbx' = 1725.0 psi  (CSI = 0.82)   ➜  OK
Beam Design 2020A34
3/2/2020 4
fv* = = 65.21 psi
 fv* = 65.21 psi < Fvx' = 155.25 psi  (CSI = 0.42)   ➜  OK
fv = = 72.69 psi
 fv = 72.69 psi < Fvx' = 155.25 psi  (CSI = 0.47)   ➜  OK
Beam Design 2020A34
3/2/2020 5
ΔLL = = 0.30 in.
(L/d)LL = 141.00 / 0.30 = 470
 ΔLL = 0.30 in = L/470 < L/240   ➜  OK
ΔTL = = 0.54 in.
(L/d)TL = 141.00 / 0.54 = 262
 ΔTL = 0.54 in = L/262 < L/180   ➜  OK
fc⊥ = = 119.6 psi
 fc⊥ = 119.6 psi < Fc⊥x' = 425.00 psi  (CSI = 0.28)   ➜  OK
Beam Design 2020A34
3/2/2020 6
