Grade: SPF No.2
Size: 2 x 4
Design Span (L): 4.75 ft.
Clear Span: 4.50 ft.
Total Span: 5.00 ft.
Live Load: 47 plf
Dead Load: 10 plf
Selfweight: 5.0 lbs
Dist. Selfweight: 1.06 plf
Total Weight: 5.3 lbs
Beam Design 2020A33
3/2/2020 1
d = 3.500 in.
A = 1.500 x 3.500 = 5.25 in.2
Beam Design 2020A33
3/2/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [5.25 x (57.00 + 3)] x (12 in./ft.)3 = 0.18 ft3
Volumespan = N[A x L] = 1 x [5.25 x 57.00] x (12 in./ft.)3 = 0.17 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.18 = 5.3 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.17 = 5.0 lbs
Distributed Self Weight (ws) = = 1.06 plf
47 plf
10 plf
ws = 1.06 plf
4.75 ft.
4.50 ft.
5.00 ft.
145.15 lbs
145.15 lbs
Beam Design 2020A33
3/2/2020 3
Fbx' = (875)(1.15)(1)(1)(1)(1.5)(1)(1.15) = 1735.8 psi
fb = = 641.6 psi
 fb = 641.6 psi < Fbx' = 1735.8 psi  (CSI = 0.37)   ➜  OK
Beam Design 2020A33
3/2/2020 4
fv* = = 34.56 psi
 fv* = 34.56 psi < Fvx' = 155.25 psi  (CSI = 0.22)   ➜  OK
fv = = 39.40 psi
 fv = 39.40 psi < Fvx' = 155.25 psi  (CSI = 0.25)   ➜  OK
Beam Design 2020A33
3/2/2020 5
ΔLL = = 0.07 in.
(L/d)LL = 57.00 / 0.07 = 794
 ΔLL = 0.07 in = L/794 < L/240   ➜  OK
ΔTL = = 0.09 in.
(L/d)TL = 57.00 / 0.09 = 643
 ΔTL = 0.09 in = L/643 < L/180   ➜  OK
fc⊥ = = 32.3 psi
 fc⊥ = 32.3 psi < Fc⊥x' = 425.00 psi  (CSI = 0.08)   ➜  OK
Beam Design 2020A33
3/2/2020 6
