Size: 5.5 x 18
Design Span (L): 16.58 ft.
Clear Span: 16.00 ft.
Total Span: 17.17 ft.
Bearing (lb): 7 in.
Dead Load: 40 plf
Selfweight: 384.9 lbs
Dist. Selfweight: 23.21 plf
Total Weight: 398.4 lbs
CV Volume Factor 0.976b - - - - -
Beam Design 2020A31
3/1/2020 1
d = 18.000 in.
Beam Design 2020A31
3/1/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [99.00 x (199.00 + 7)] x (12 in./ft.)3 = 11.80 ft3
Volumespan = N[A x L] = 1 x [99.00 x 199.00] x (12 in./ft.)3 = 11.40 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 11.80 = 398.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 11.40 = 384.9 lbs
40 plf
  ws = 23.21 plf
16.58 ft.
17.17 ft.
1400.87 lbs
1400.87 lbs
Beam Design 2020A31
3/1/2020 3
CV = = 0.976
CV = 0.976 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.976) = 2694.6 psi
fb = = 226.7 psi
 fb = 226.7 psi < Fbx' = 2694.6 psi  (CSI = 0.08)   ➜  OK
Beam Design 2020A31
3/1/2020 4
fv* = = 16.79 psi
 fv* = 16.79 psi < Fvx' = 304.75 psi  (CSI = 0.06)   ➜  OK
fv = = 20.50 psi
 fv = 20.50 psi < Fvx' = 304.75 psi  (CSI = 0.07)   ➜  OK
Beam Design 2020A31
3/1/2020 5
ΔLL = = 0.04 in.
(L/d)LL = 199.00 / 0.04 = 5627
 ΔLL = 0.04 in = L/5627 < L/360   ➜  OK
ΔTL = = 0.06 in.
(L/d)TL = 199.00 / 0.06 = 3448
 ΔTL = 0.06 in = L/3448 < L/240   ➜  OK
Ab = b x lb = 5.5 x 7 = 38.50 in2
fc⊥ = = 36.4 psi
 fc⊥ = 36.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.06)   ➜  OK
Beam Design 2020A31
3/1/2020 6
