Design Span (L): 18.25 ft.
Clear Span: 18.00 ft.
Total Span: 18.50 ft.
Live Load: 40 plf
Dead Load: 20 plf
Selfweight: 154.4 lbs
Dist. Selfweight: 8.46 plf
Total Weight: 156.5 lbs
Beam Design 2020A297
12/28/2020 1
12/28/2020 2
Volumetotal = N[A x (L + lb)] = 3 x [10.88 x (219.00 + 3)] x (12 in./ft.)3 = 4.19 ft3
Volumespan = N[A x L] = 3 x [10.88 x 219.00] x (12 in./ft.)3 = 4.13 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 4.19 = 156.5 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 4.13 = 154.4 lbs
Distributed Self Weight (ws) = = 8.46 plf
40 plf
20 plf
ws = 8.46 plf
18.25 ft.
18.00 ft.
18.50 ft.
633.23 lbs
633.23 lbs
12/28/2020 3
Fbx' = (925)(1.15)(1)(1)(1)(1)(1)(1) = 1063.8 psi
fb = = 867.6 psi
 fb = 867.6 psi < Fbx' = 1063.8 psi  (CSI = 0.82)   ➜  OK
12/28/2020 4
fv* = = 26.82 psi
 fv* = 26.82 psi < Fvx' = 201.25 psi  (CSI = 0.13)   ➜  OK
fv = = 28.72 psi
 fv = 28.72 psi < Fvx' = 201.25 psi  (CSI = 0.14)   ➜  OK
12/28/2020 5
ΔLL = = 0.50 in.
(L/d)LL = 219.00 / 0.50 = 439
 ΔLL = 0.50 in = L/439 < L/360   ➜  OK
ΔTL = = 0.85 in.
(L/d)TL = 219.00 / 0.85 = 256
 ΔTL = 0.85 in = L/256 < L/240   ➜  OK
fc⊥ = = 46.9 psi
 fc⊥ = 46.9 psi < Fc⊥x' = 565.00 psi  (CSI = 0.08)   ➜  OK
12/28/2020 6
