Size: 4 x 8
Design Span (L): 12.75 ft.
Clear Span: 12.50 ft.
Total Span: 13.00 ft.
Live Load: 258.75 plf
Dead Load: 215.63 plf
Selfweight: 79.7 lbs
Dist. Selfweight: 6.25 plf
Total Weight: 81.2 lbs
Beam Design 2020A293
12/22/2020 1
12/22/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [25.38 x (153.00 + 3)] x (12 in./ft.)3 = 2.29 ft3
Volumespan = N[A x L] = 1 x [25.38 x 153.00] x (12 in./ft.)3 = 2.25 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 2.29 = 81.2 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 2.25 = 79.7 lbs
Distributed Self Weight (ws) = = 6.25 plf
258.75 plf
215.63 plf
ws = 6.25 plf
12.75 ft.
12.50 ft.
13.00 ft.
3124.09 lbs
3124.09 lbs
12/22/2020 3
Fbx' = (900)(1.15)(0.85)(1)(1)(1.3)(1)(1) = 1143.7 psi
fb = = 3822.3 psi
 fb = 3822.3 psi > Fbx' = 1143.7 psi  (CSI = 3.34)   ➜  NG
12/22/2020 4
fv* = = 163.96 psi
 fv* = 163.96 psi < Fvx' = 200.79 psi  (CSI = 0.82)   ➜  OK
fv = = 181.12 psi
 fv = 181.12 psi < Fvx' = 200.79 psi  (CSI = 0.90)   ➜  OK
12/22/2020 5
ΔLL = = 0.96 in.
(L/d)LL = 153.00 / 0.96 = 159
 ΔLL = 0.96 in = L/159 > L/360   ➜  NG
ΔTL = = 1.79 in.
(L/d)TL = 153.00 / 1.79 = 86
 ΔTL = 1.79 in = L/86 > L/240   ➜  NG
fc⊥ = = 297.5 psi
 fc⊥ = 297.5 psi < Fc⊥x' = 418.75 psi  (CSI = 0.71)   ➜  OK
12/22/2020 6
