Beam Design - Winchcombe
Grade: DF No.1
Size: 4 x 4
Design Span (L): 2.85 ft.
Clear Span: 2.71 ft.
Total Span: 3.00 ft.
Bearing (lb): 1.75 in.
Live Load: 1042 lbs
Dead Load: 340 lbs
Selfweight: 8.3 lbs
Dist. Selfweight: 2.91 plf
Total Weight: 8.7 lbs
Beam Design Kat West 007
12/16/2020 1
d = 3.500 in.
12/16/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [12.25 x (34.25 + 1.75)] x (12 in./ft.)3 = 0.26 ft3
Volumespan = N[A x L] = 1 x [12.25 x 34.25] x (12 in./ft.)3 = 0.24 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.26 = 8.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.24 = 8.3 lbs
1042 lbs
340 lbs
ws = 2.91 plf
2.85 ft.
2.71 ft.
3.00 ft.
695.36 lbs
695.36 lbs
12/16/2020 3
Fbx' = (1000)(1.15)(1)(1)(1)(1.5)(1)(1) = 1725.0 psi
fb = = 1660.9 psi
 fb = 1660.9 psi < Fbx' = 1725.0 psi  (CSI = 0.96)   ➜  OK
12/16/2020 4
fv* = = 85.02 psi
 fv* = 85.02 psi < Fvx' = 207.00 psi  (CSI = 0.41)   ➜  OK
fv = = 85.12 psi
 fv = 85.12 psi < Fvx' = 207.00 psi  (CSI = 0.41)   ➜  OK
12/16/2020 5
ΔLL =   =   = 0.04 in.
(L/d)LL = 34.25 / 0.04 = 835
 ΔLL = 0.04 in = L/835 < L/180   ➜  OK
ΔTL =   =   = 0.05 in.
(L/d)TL = 34.25 / 0.05 = 627
 ΔTL = 0.05 in = L/627 < L/120   ➜  OK
Ab = b x lb = 3.5 x 1.75 = 6.13 in2
fc⊥ = = 113.5 psi
 fc⊥ = 113.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.18)   ➜  OK
12/16/2020 6
