Grade: SP SS
Design Span (L): 20.58 ft.
Clear Span: 20.41 ft.
Total Span: 20.75 ft.
Bearing (lb): 2 in.
Quantity (N): 10
Live Load: 2150 lbs
Dead Load: 800 lbs
Selfweight: 900.3 lbs
Dist. Selfweight: 43.75 plf
Total Weight: 907.6 lbs
Beam Design 2020A284
12/14/2020 1
SP SS 1600 1100 175 565 1650 1800000 660000 0.55
12/14/2020 2
Volumetotal = N[A x (L + lb)] = 10 x [16.88 x (246.96 + 2)] x (12 in./ft.)3 = 24.31 ft3
Volumespan = N[A x L] = 10 x [16.88 x 246.96] x (12 in./ft.)3 = 24.12 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 24.31 = 907.6 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 24.12 = 900.3 lbs
Distributed Self Weight (ws) = = 43.75 plf
2150 lbs
800 lbs
ws = 43.75 plf
20.58 ft.
20.41 ft.
20.75 ft.
1928.79 lbs
1928.79 lbs
12/14/2020 3
Fbx' = (1600)(1.00)(1)(1)(1)(1)(1)(1) = 1600.0 psi
fb = = 663.5 psi
 fb = 663.5 psi < Fbx' = 1600.0 psi  (CSI = 0.41)   ➜  OK
12/14/2020 4
fv* = = 16.75 psi
 fv* = 16.75 psi < Fvx' = 175.00 psi  (CSI = 0.10)   ➜  OK
fv = = 17.11 psi
 fv = 17.11 psi < Fvx' = 175.00 psi  (CSI = 0.10)   ➜  OK
12/14/2020 5
ΔLL =   =   = 0.21 in.
(L/d)LL = 246.96 / 0.21 = 1173
 ΔLL = 0.21 in = L/1173 < L/360   ➜  OK
ΔTL =   =   = 0.34 in.
(L/d)TL = 246.96 / 0.34 = 718
 ΔTL = 0.34 in = L/718 < L/240   ➜  OK
fc⊥ = = 64.3 psi
 fc⊥ = 64.3 psi < Fc⊥x' = 565.00 psi  (CSI = 0.11)   ➜  OK
12/14/2020 6
