Grade: SP DSS
Size: 2 x 4
Design Span (L): 6.75 ft.
Clear Span: 6.59 ft.
Total Span: 6.92 ft.
Bearing (lb): 2 in.
Quantity (N): 10
Live Load: 64 plf
Dead Load: 24 plf
Selfweight: 91.9 lbs
Dist. Selfweight: 13.61 plf
Total Weight: 94.2 lbs
Beam Design 2020A283
12/14/2020 1
d = 3.500 in.
A = 1.500 x 3.500 = 5.25 in.2
SP DSS 2700 1900 175 660 2050 1900000 690000 0.55
12/14/2020 2
Volumetotal = N[A x (L + lb)] = 10 x [5.25 x (81.04 + 2)] x (12 in./ft.)3 = 2.52 ft3
Volumespan = N[A x L] = 10 x [5.25 x 81.04] x (12 in./ft.)3 = 2.46 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 2.52 = 94.2 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 2.46 = 91.9 lbs
Distributed Self Weight (ws) = = 13.61 plf
64 plf
24 plf
ws = 13.61 plf
6.75 ft.
6.59 ft.
6.92 ft.
351.55 lbs
351.55 lbs
12/14/2020 3
Fbx' = (2700)(1.00)(1)(1)(1)(1)(1)(1) = 2700.0 psi
fb = = 227.0 psi
 fb = 227.0 psi < Fbx' = 2700.0 psi  (CSI = 0.08)   ➜  OK
12/14/2020 4
fv* = = 8.96 psi
 fv* = 8.96 psi < Fvx' = 175.00 psi  (CSI = 0.05)   ➜  OK
fv = = 9.80 psi
 fv = 9.80 psi < Fvx' = 175.00 psi  (CSI = 0.06)   ➜  OK
12/14/2020 5
ΔLL = = 0.03 in.
(L/d)LL = 81.04 / 0.03 = 2755
 ΔLL = 0.03 in = L/2755 < L/360   ➜  OK
ΔTL = = 0.05 in.
(L/d)TL = 81.04 / 0.05 = 1736
 ΔTL = 0.05 in = L/1736 < L/240   ➜  OK
fc⊥ = = 11.7 psi
 fc⊥ = 11.7 psi < Fc⊥x' = 660.00 psi  (CSI = 0.02)   ➜  OK
12/14/2020 6
