Design Span (L): 6.25 ft.
Clear Span: 6.00 ft.
Total Span: 6.50 ft.
Live Load: 30 plf
Dead Load: 15 plf
Selfweight: 20.6 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 21.4 lbs
Beam Design 2020A280
12/11/2020 1
12/11/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (75.00 + 3)] x (12 in./ft.)3 = 0.63 ft3
Volumespan = N[A x L] = 1 x [13.88 x 75.00] x (12 in./ft.)3 = 0.60 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.63 = 21.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.60 = 20.6 lbs
30 plf
15 plf
ws = 3.30 plf
6.25 ft.
6.50 ft.
156.96 lbs
156.96 lbs
12/11/2020 3
fb = = 132.3 psi
 fb = 132.3 psi < Fbx' = 1138.5 psi  (CSI = 0.12)   ➜  OK
12/11/2020 4
fv* = = 12.29 psi
 fv* = 12.29 psi < Fvx' = 207.00 psi  (CSI = 0.06)   ➜  OK
fv = = 16.32 psi
 fv = 16.32 psi < Fvx' = 207.00 psi  (CSI = 0.08)   ➜  OK
12/11/2020 5
ΔLL = = 0.01 in.
(L/d)LL = 75.00 / 0.01 = 11526
 ΔLL = 0.01 in = L/11526 < L/180   ➜  OK
ΔTL = = 0.01 in.
(L/d)TL = 75.00 / 0.01 = 7160
 ΔTL = 0.01 in = L/7160 < L/120   ➜  OK
fc⊥ = = 34.9 psi
 fc⊥ = 34.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.06)   ➜  OK
12/11/2020 6
