Live Load: 40 plf
Dead Load: 10 plf
Selfweight: 154.2 lbs
Dist. Selfweight: 13.12 plf
Total Weight: 157.5 lbs
Beam Design 2020A279
12/10/2020 1
12/10/2020 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (141.00 + 3)] x (12 in./ft.)3 = 4.22 ft3
Volumespan = N[A x L] = 3 x [16.88 x 141.00] x (12 in./ft.)3 = 4.13 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 4.22 = 157.5 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 4.13 = 154.2 lbs
40 plf
10 plf
ws = 13.12 plf
378.74 lbs
378.74 lbs
12/10/2020 3
Fbx' = (750)(1.00)(1)(1)(1)(1)(1)(1) = 750.0 psi
fb = = 137.7 psi
 fb = 137.7 psi < Fbx' = 750.0 psi  (CSI = 0.18)   ➜  OK
12/10/2020 4
fv* = = 9.23 psi
 fv* = 9.23 psi < Fvx' = 175.00 psi  (CSI = 0.05)   ➜  OK
fv = = 10.99 psi
 fv = 10.99 psi < Fvx' = 175.00 psi  (CSI = 0.06)   ➜  OK
12/10/2020 5
ΔLL = = 0.02 in.
(L/d)LL = 141.00 / 0.02 = 6144
 ΔLL = 0.02 in = L/6144 < L/360   ➜  OK
ΔTL = = 0.04 in.
(L/d)TL = 141.00 / 0.04 = 3893
 ΔTL = 0.04 in = L/3893 < L/240   ➜  OK
fc⊥ = = 28.1 psi
 fc⊥ = 28.1 psi < Fc⊥x' = 565.00 psi  (CSI = 0.05)   ➜  OK
12/10/2020 6
