Size: 4 x 12
Design Span (L): 6.67 ft.
Clear Span: 6.42 ft.
Total Span: 6.92 ft.
Live Load: 650 plf
Dead Load: 250 plf
Selfweight: 62.4 lbs
Dist. Selfweight: 9.35 plf
Total Weight: 64.7 lbs
CL Beam Stability Factor 0.987 - - - - -
CF Size Factor 1.1 1 - 1 - -
Beam Design 2020A276
12/8/2020 1
12/8/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (80.00 + 3)] x (12 in./ft.)3 = 1.89 ft3
Volumespan = N[A x L] = 1 x [39.38 x 80.00] x (12 in./ft.)3 = 1.82 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.89 = 64.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.82 = 62.4 lbs
650 plf
250 plf
ws = 9.35 plf
6.67 ft.
6.42 ft.
6.92 ft.
3145.00 lbs
3145.00 lbs
12/8/2020 3
lu = Unbraced Length = 6.667 ft.
lu/d = = 7.11
le = 1.63lu + 3d = 1.63(80.0) + 3(11.25) = 164.16 in. = 13.68 ft.  (NDS Table 3.3.3)
Rb = = 12.28
 Rb = 12.28 < 50   ➜  OK
12/8/2020 4
FbE = = 4616.73 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.00)(1)(1)(1.1)(1)(1) = 990.00 psi
CL =   = 0.987
Fbx' = (900)(1.00)(1)(1)(0.987)(1.1)(1)(1) = 976.9 psi
fb = = 821.2 psi
 fb = 821.2 psi < Fbx' = 976.9 psi  (CSI = 0.84)   ➜  OK
fv* = = 83.00 psi
 fv* = 83.00 psi < Fvx' = 180.00 psi  (CSI = 0.46)   ➜  OK
fv = = 115.48 psi
 fv = 115.48 psi < Fvx' = 180.00 psi  (CSI = 0.64)   ➜  OK
12/8/2020 5
ΔLL = = 0.04 in.
(L/d)LL = 80.00 / 0.04 = 1840
 ΔLL = 0.04 in = L/1840 < L/240   ➜  OK
ΔTL = = 0.06 in.
(L/d)TL = 80.00 / 0.06 = 1315
 ΔTL = 0.06 in = L/1315 < L/180   ➜  OK
fc⊥ = = 299.5 psi
 fc⊥ = 299.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.48)   ➜  OK
12/8/2020 6
