Design Span (L): 6.67 ft.
Clear Span: 6.42 ft.
Total Span: 6.92 ft.
Live Load: 500 plf
Dead Load: 150 plf
Selfweight: 53.4 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 55.4 lbs
Beam Design 2020A275
12/8/2020 1
12/8/2020 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (80.00 + 3)] x (12 in./ft.)3 = 1.62 ft3
Volumespan = N[A x L] = 2 x [16.88 x 80.00] x (12 in./ft.)3 = 1.56 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.62 = 55.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.56 = 53.4 lbs
500 plf
150 plf
ws = 8.02 plf
6.67 ft.
6.42 ft.
6.92 ft.
2275.75 lbs
2275.75 lbs
12/8/2020 3
lu = Unbraced Length = 6.667 ft.
lu/d = = 7.11
le = 1.63lu + 3d = 1.63(80.0) + 3(11.25) = 164.16 in. = 13.68 ft.  (NDS Table 3.3.3)
Rb = = 14.32
 Rb = 14.32 < 50   ➜  OK
12/8/2020 4
FbE = = 3391.88 psi
CL =   = 0.983
Fbx' = (900)(1.00)(1)(1)(0.983)(1)(1)(1) = 884.4 psi
fb = = 693.3 psi
 fb = 693.3 psi < Fbx' = 884.4 psi  (CSI = 0.78)   ➜  OK
fv* = = 70.07 psi
 fv* = 70.07 psi < Fvx' = 180.00 psi  (CSI = 0.39)   ➜  OK
fv = = 97.49 psi
 fv = 97.49 psi < Fvx' = 180.00 psi  (CSI = 0.54)   ➜  OK
12/8/2020 5
ΔLL = = 0.04 in.
(L/d)LL = 80.00 / 0.04 = 2050
 ΔLL = 0.04 in = L/2050 < L/240   ➜  OK
ΔTL = = 0.05 in.
(L/d)TL = 80.00 / 0.05 = 1558
 ΔTL = 0.05 in = L/1558 < L/180   ➜  OK
fc⊥ = = 252.9 psi
 fc⊥ = 252.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.40)   ➜  OK
12/8/2020 6
