Size: 2 x 4
Design Span (L): 3.75 ft.
Clear Span: 3.50 ft.
Total Span: 4.00 ft.
Selfweight: 5.1 lbs
Dist. Selfweight: 1.36 plf
Total Weight: 5.4 lbs
Beam Design 2020A272
12/7/2020 1
d = 3.500 in.
A = 1.500 x 3.500 = 5.25 in.2
SP No.2 1100 675 175 565 1450 1400000 510000 0.55
12/7/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [5.25 x (45.00 + 3)] x (12 in./ft.)3 = 0.15 ft3
Volumespan = N[A x L] = 1 x [5.25 x 45.00] x (12 in./ft.)3 = 0.14 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.15 = 5.4 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.14 = 5.1 lbs
Distributed Self Weight (ws) = = 1.36 plf
ws = 1.36 plf
3.75 ft.
3.50 ft.
4.00 ft.
352.72 lbs
352.72 lbs
12/7/2020 3
Fbx' = (1100)(1.15)(1)(1)(1)(1)(1)(1) = 1265.0 psi
fb = = 1214.7 psi
 fb = 1214.7 psi < Fbx' = 1265.0 psi  (CSI = 0.96)   ➜  OK
12/7/2020 4
fv* = = 79.78 psi
 fv* = 79.78 psi < Fvx' = 201.25 psi  (CSI = 0.40)   ➜  OK
fv = = 94.48 psi
 fv = 94.48 psi < Fvx' = 201.25 psi  (CSI = 0.47)   ➜  OK
12/7/2020 5
ΔLL = = 0.06 in.
(L/d)LL = 45.00 / 0.06 = 759
 ΔLL = 0.06 in = L/759 < L/360   ➜  OK
ΔTL = = 0.10 in.
(L/d)TL = 45.00 / 0.10 = 430
 ΔTL = 0.10 in = L/430 < L/240   ➜  OK
fc⊥ = = 78.4 psi
 fc⊥ = 78.4 psi < Fc⊥x' = 565.00 psi  (CSI = 0.14)   ➜  OK
12/7/2020 6
