Size: 3.125 x 6
Design Span (L): 11.85 ft.
Clear Span: 11.60 ft.
Total Span: 12.10 ft.
Selfweight: 52.1 lbs
Dist. Selfweight: 4.40 plf
Total Weight: 53.2 lbs
CL Beam Stability Factor 0.974 - - - - -
Beam Design 2020A263
12/2/2020 1
b = 3.125 in.
d = 6.000 in.
A = 3.125 x 6.000 = 18.75 in.2
Sx = (3.125)(6.000)2/6 = 18.75 in.3
Sy = (3.125)2(6.000)/6 = 9.77 in.3
Ix = (3.125)(6.000)3/12 = 56.25 in.4
Iy = (3.125)3(6.000)/12 = 15.26 in.4
12/2/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [18.75 x (142.20 + 3)] x (12 in./ft.)3 = 1.58 ft3
Volumespan = N[A x L] = 1 x [18.75 x 142.20] x (12 in./ft.)3 = 1.54 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 1.58 = 53.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 1.54 = 52.1 lbs
Distributed Self Weight (ws) = = 4.40 plf
  ws = 4.40 plf
11.85 ft.
11.60 ft.
12.10 ft.
1085.35 lbs
1085.35 lbs
12/2/2020 3
lu = Unbraced Length = 11.850 ft.
lu/d = = 23.70
le = 1.63lu + 3d = 1.63(142.2) + 3(6) = 249.79 in. = 20.82 ft.  (NDS Table 3.3.3)
Rb = = 12.39
 Rb = 12.39 < 50   ➜  OK
12/2/2020 4
FbE = = 6646.31 psi
Fbx* = Fbx(CD)(CM)(Ct) = (2400)(1.00)(1)(1) = 2400.00 psi
CL =   = 0.974
CL = 0.974 < CV = 1.0
Fbx' = (2400)(1.00)(1)(1)(0.974) = 2336.7 psi
fb = = 2015.3 psi
 fb = 2015.3 psi < Fbx' = 2336.7 psi  (CSI = 0.86)   ➜  OK
fv* = = 77.86 psi
12/2/2020 5
 fv* = 77.86 psi < Fvx' = 265.00 psi  (CSI = 0.29)   ➜  OK
fv = = 85.03 psi
 fv = 85.03 psi < Fvx' = 265.00 psi  (CSI = 0.32)   ➜  OK
ΔLL = = 0.44 in.
(L/d)LL = 142.20 / 0.44 = 325
 ΔLL = 0.44 in = L/325 < L/180   ➜  OK
ΔTL = = 0.79 in.
(L/d)TL = 142.20 / 0.79 = 181
 ΔTL = 0.79 in = L/181 < L/120   ➜  OK
12/2/2020 6
fc⊥ = = 115.8 psi
 fc⊥ = 115.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.18)   ➜  OK
12/2/2020 7
