Size: 3.5 x 6
Design Span (L): 11.95 ft.
Clear Span: 11.70 ft.
Total Span: 12.20 ft.
Selfweight: 58.8 lbs
Dist. Selfweight: 4.92 plf
Total Weight: 60.1 lbs
CL Beam Stability Factor 0.981 - - - - -
Beam Design 2020A261
12/2/2020 1
d = 6.000 in.
A = 3.500 x 6.000 = 21.00 in.2
Sx = (3.500)(6.000)2/6 = 21.00 in.3
Sy = (3.500)2(6.000)/6 = 12.25 in.3
Ix = (3.500)(6.000)3/12 = 63.00 in.4
Iy = (3.500)3(6.000)/12 = 21.44 in.4
12/2/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [21.00 x (143.40 + 3)] x (12 in./ft.)3 = 1.78 ft3
Volumespan = N[A x L] = 1 x [21.00 x 143.40] x (12 in./ft.)3 = 1.74 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 1.78 = 60.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 1.74 = 58.8 lbs
Distributed Self Weight (ws) = = 4.92 plf
  ws = 4.92 plf
11.95 ft.
11.70 ft.
12.20 ft.
1097.53 lbs
1097.53 lbs
12/2/2020 3
lu = Unbraced Length = 11.950 ft.
lu/d = = 23.90
le = 1.63lu + 3d = 1.63(143.4) + 3(6) = 251.74 in. = 20.98 ft.  (NDS Table 3.3.3)
Rb = = 11.10
 Rb = 11.10 < 50   ➜  OK
12/2/2020 4
FbE = = 8272.36 psi
Fbx* = Fbx(CD)(CM)(Ct) = (2400)(1.00)(1)(1) = 2400.00 psi
CL =   = 0.981
CL = 0.981 < CV = 1.0
Fbx' = (2400)(1.00)(1)(1)(0.981) = 2353.2 psi
fb = = 1835.3 psi
 fb = 1835.3 psi < Fbx' = 2353.2 psi  (CSI = 0.78)   ➜  OK
fv* = = 70.36 psi
12/2/2020 5
 fv* = 70.36 psi < Fvx' = 265.00 psi  (CSI = 0.27)   ➜  OK
fv = = 76.79 psi
 fv = 76.79 psi < Fvx' = 265.00 psi  (CSI = 0.29)   ➜  OK
ΔLL = = 0.40 in.
(L/d)LL = 143.40 / 0.40 = 354
 ΔLL = 0.40 in = L/354 < L/180   ➜  OK
ΔTL = = 0.73 in.
(L/d)TL = 143.40 / 0.73 = 197
 ΔTL = 0.73 in = L/197 < L/120   ➜  OK
12/2/2020 6
fc⊥ = = 104.5 psi
 fc⊥ = 104.5 psi < Fc⊥x' = 650.00 psi  (CSI = 0.16)   ➜  OK
12/2/2020 7
