Grade: SPF No.2
Design Span (L): 7.54 ft.
Clear Span: 7.08 ft.
Total Span: 8.00 ft.
Bearing (lb): 5.5 in.
Live Load: 450 plf
Dead Load: 112.5 plf
Selfweight: 42.3 lbs
Dist. Selfweight: 5.61 plf
Total Weight: 44.9 lbs
Notes: Porch Beam
Beam Design Hockstettler 2020A257
12/1/2020 1
12/1/2020 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (90.50 + 5.5)] x (12 in./ft.)3 = 1.54 ft3
Volumespan = N[A x L] = 2 x [13.88 x 90.50] x (12 in./ft.)3 = 1.45 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.54 = 44.9 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.45 = 42.3 lbs
450 plf
112.5 plf
ws = 5.61 plf
7.54 ft.
7.08 ft.
2272.52 lbs
2272.52 lbs
12/1/2020 3
lu/d = = 2.59
Rb = = 7.13
 Rb = 7.13 < 50   ➜  OK
12/1/2020 4
FbE = = 12044.08 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (875)(1.15)(1)(1)(1.1)(1)(1) = 1106.88 psi
CL =   = 0.995
Fbx' = (875)(1.15)(1)(1)(0.995)(1.1)(1)(1) = 1101.3 psi
fb = = 1133.0 psi
 fb = 1133.0 psi > Fbx' = 1101.3 psi  (CSI = 1.03)   ➜  NG
fv* = = 92.13 psi
 fv* = 92.13 psi < Fvx' = 155.25 psi  (CSI = 0.59)   ➜  OK
fv = = 115.80 psi
 fv = 115.80 psi < Fvx' = 155.25 psi  (CSI = 0.75)   ➜  OK
12/1/2020 5
ΔLL = = 0.12 in.
(L/d)LL = 90.50 / 0.12 = 765
 ΔLL = 0.12 in = L/765 < L/360   ➜  OK
ΔTL = = 0.15 in.
(L/d)TL = 90.50 / 0.15 = 606
 ΔTL = 0.15 in = L/606 < L/240   ➜  OK
fc⊥ = = 137.7 psi
 fc⊥ = 137.7 psi < Fc⊥x' = 425.00 psi  (CSI = 0.32)   ➜  OK
12/1/2020 6
