Size: 6.75 x 9
Design Span (L): 21.29 ft.
Clear Span: 21.00 ft.
Total Span: 21.58 ft.
Bearing (lb): 3.5 in.
Live Load: 200 plf
Dead Load: 150 plf
Selfweight: 303.3 lbs
Dist. Selfweight: 14.24 plf
Total Weight: 307.4 lbs
Load Duration: 1.25
CV Volume Factor 1.000b - - - - -
Beam Design 2020A252
12/1/2020 1
b = 6.750 in.
d = 9.000 in.
A = 6.750 x 9.000 = 60.75 in.2
Sx = (6.750)(9.000)2/6 = 91.13 in.3
Sy = (6.750)2(9.000)/6 = 68.34 in.3
Ix = (6.750)(9.000)3/12 = 410.06 in.4
Iy = (6.750)3(9.000)/12 = 230.66 in.4
12/1/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [60.75 x (255.50 + 3.5)] x (12 in./ft.)3 = 9.11 ft3
Volumespan = N[A x L] = 1 x [60.75 x 255.50] x (12 in./ft.)3 = 8.98 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 9.11 = 307.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 8.98 = 303.3 lbs
Distributed Self Weight (ws) = = 14.24 plf
200 plf
150 plf
  ws = 14.24 plf
21.29 ft.
21.00 ft.
21.58 ft.
3930.85 lbs
3930.85 lbs
12/1/2020 3
CV = = 1.000
CV = 1.000 < CL = 1
Fbx' = (2400)(1.25)(1)(1)(1.000) = 2999.5 psi
fb = = 2718.2 psi
 fb = 2718.2 psi < Fbx' = 2999.5 psi  (CSI = 0.91)   ➜  OK
12/1/2020 4
fv* = = 89.00 psi
 fv* = 89.00 psi < Fvx' = 331.25 psi  (CSI = 0.27)   ➜  OK
fv = = 95.75 psi
 fv = 95.75 psi < Fvx' = 331.25 psi  (CSI = 0.29)   ➜  OK
12/1/2020 5
ΔLL = = 1.25 in.
(L/d)LL = 255.50 / 1.25 = 204
 ΔLL = 1.25 in = L/204 < L/180   ➜  OK
ΔTL = = 2.28 in.
(L/d)TL = 255.50 / 2.28 = 112
 ΔTL = 2.28 in = L/112 > L/120   ➜  NG
Ab = b x lb = 6.75 x 3.5 = 23.63 in2
fc⊥ = = 166.4 psi
 fc⊥ = 166.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.26)   ➜  OK
12/1/2020 6
