Size: 4 x 6
Design Span (L): 3.25 ft.
Clear Span: 3.00 ft.
Total Span: 3.50 ft.
Live Load: 20 plf
Dead Load: 800 plf
Selfweight: 14.9 lbs
Dist. Selfweight: 4.57 plf
Total Weight: 16.0 lbs
Defl. Limits: 900|600
Load Duration: 1.25
Beam Design 2020A249
12/1/2020 1
12/1/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (39.00 + 3)] x (12 in./ft.)3 = 0.47 ft3
Volumespan = N[A x L] = 1 x [19.25 x 39.00] x (12 in./ft.)3 = 0.43 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.47 = 16.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.43 = 14.9 lbs
20 plf
800 plf
ws = 4.57 plf
3.25 ft.
3.00 ft.
3.50 ft.
1443.00 lbs
1443.00 lbs
12/1/2020 3
Fbx' = (900)(1.25)(1)(1)(1)(1.3)(1)(1) = 1462.5 psi
fb = = 740.4 psi
 fb = 740.4 psi < Fbx' = 1462.5 psi  (CSI = 0.51)   ➜  OK
12/1/2020 4
fv* = = 74.96 psi
 fv* = 74.96 psi < Fvx' = 225.00 psi  (CSI = 0.33)   ➜  OK
fv = = 104.41 psi
 fv = 104.41 psi < Fvx' = 225.00 psi  (CSI = 0.46)   ➜  OK
LL Allowable: L/900
TL Allowable: L/600
12/1/2020 5
ΔLL = = 0.00 in.
(L/d)LL = 39.00 / 0.00 = 60313
 ΔLL = 0.00 in = L/60313 < L/900   ➜  OK
ΔTL = = 0.03 in.
(L/d)TL = 39.00 / 0.03 = 1463
 ΔTL = 0.03 in = L/1463 < L/600   ➜  OK
fc⊥ = = 137.4 psi
 fc⊥ = 137.4 psi < Fc⊥x' = 625.00 psi  (CSI = 0.22)   ➜  OK
12/1/2020 6
