Design Span (L): 9.25 ft.
Clear Span: 9.00 ft.
Total Span: 9.50 ft.
Live Load: 20 plf
Dead Load: 38 plf
Selfweight: 18.1 lbs
Dist. Selfweight: 1.96 plf
Total Weight: 18.6 lbs
Defl. Limits: 900|600
Beam Design 2020A247
12/1/2020 1
12/1/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (111.00 + 3)] x (12 in./ft.)3 = 0.54 ft3
Volumespan = N[A x L] = 1 x [8.25 x 111.00] x (12 in./ft.)3 = 0.53 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.54 = 18.6 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.53 = 18.1 lbs
20 plf
38 plf
ws = 1.96 plf
9.25 ft.
9.00 ft.
9.50 ft.
284.81 lbs
284.81 lbs
12/1/2020 3
fb = = 1017.6 psi
 fb = 1017.6 psi < Fbx' = 1170.0 psi  (CSI = 0.87)   ➜  OK
12/1/2020 4
fv* = = 45.42 psi
 fv* = 45.42 psi < Fvx' = 180.00 psi  (CSI = 0.25)   ➜  OK
fv = = 50.42 psi
 fv = 50.42 psi < Fvx' = 180.00 psi  (CSI = 0.28)   ➜  OK
LL Allowable: L/900
TL Allowable: L/600
12/1/2020 5
ΔLL = = 0.10 in.
(L/d)LL = 111.00 / 0.10 = 1121
 ΔLL = 0.10 in = L/1121 < L/900   ➜  OK
ΔTL = = 0.30 in.
(L/d)TL = 111.00 / 0.30 = 374
 ΔTL = 0.30 in = L/374 > L/600   ➜  NG
fc⊥ = = 63.3 psi
 fc⊥ = 63.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.10)   ➜  OK
12/1/2020 6
