Size: 6.75 x 7.5
Design Span (L): 21.29 ft.
Clear Span: 21.00 ft.
Total Span: 21.58 ft.
Bearing (lb): 3.5 in.
Selfweight: 252.7 lbs
Dist. Selfweight: 11.87 plf
Total Weight: 256.2 lbs
Load Duration: 1.25
Beam Design 2020A246
12/1/2020 1
b = 6.750 in.
d = 7.500 in.
A = 6.750 x 7.500 = 50.63 in.2
Sx = (6.750)(7.500)2/6 = 63.28 in.3
Sy = (6.750)2(7.500)/6 = 56.95 in.3
Ix = (6.750)(7.500)3/12 = 237.30 in.4
Iy = (6.750)3(7.500)/12 = 192.22 in.4
12/1/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [50.63 x (255.50 + 3.5)] x (12 in./ft.)3 = 7.59 ft3
Volumespan = N[A x L] = 1 x [50.63 x 255.50] x (12 in./ft.)3 = 7.49 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 7.59 = 256.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 7.49 = 252.7 lbs
Distributed Self Weight (ws) = = 11.87 plf
  ws = 11.87 plf
21.29 ft.
21.00 ft.
21.58 ft.
2016.66 lbs
2016.66 lbs
12/1/2020 3
Fbx' = (2400)(1.25)(1)(1)(1.0) = 3000.0 psi
fb = = 2008.1 psi
 fb = 2008.1 psi < Fbx' = 3000.0 psi  (CSI = 0.67)   ➜  OK
12/1/2020 4
fv* = = 55.48 psi
 fv* = 55.48 psi < Fvx' = 331.25 psi  (CSI = 0.17)   ➜  OK
fv = = 58.95 psi
 fv = 58.95 psi < Fvx' = 331.25 psi  (CSI = 0.18)   ➜  OK
12/1/2020 5
ΔLL = = 1.08 in.
(L/d)LL = 255.50 / 1.08 = 236
 ΔLL = 1.08 in = L/236 < L/180   ➜  OK
ΔTL = = 2.02 in.
(L/d)TL = 255.50 / 2.02 = 126
 ΔTL = 2.02 in = L/126 < L/120   ➜  OK
Ab = b x lb = 6.75 x 3.5 = 23.63 in2
fc⊥ = = 85.4 psi
 fc⊥ = 85.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.13)   ➜  OK
12/1/2020 6
