Size: 5.5 x 9
Design Span (L): 21.29 ft.
Clear Span: 21.00 ft.
Total Span: 21.58 ft.
Bearing (lb): 3.5 in.
Selfweight: 247.1 lbs
Dist. Selfweight: 11.61 plf
Total Weight: 250.5 lbs
Load Duration: 1.25
Beam Design 2020A245
12/1/2020 1
d = 9.000 in.
12/1/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [49.50 x (255.50 + 3.5)] x (12 in./ft.)3 = 7.42 ft3
Volumespan = N[A x L] = 1 x [49.50 x 255.50] x (12 in./ft.)3 = 7.32 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 7.42 = 250.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 7.32 = 247.1 lbs
Distributed Self Weight (ws) = = 11.61 plf
  ws = 11.61 plf
21.29 ft.
21.00 ft.
21.58 ft.
2013.81 lbs
2013.81 lbs
12/1/2020 3
Fbx' = (2400)(1.25)(1)(1)(1.0) = 3000.0 psi
fb = = 1709.0 psi
 fb = 1709.0 psi < Fbx' = 3000.0 psi  (CSI = 0.57)   ➜  OK
12/1/2020 4
fv* = = 55.96 psi
 fv* = 55.96 psi < Fvx' = 331.25 psi  (CSI = 0.17)   ➜  OK
fv = = 60.20 psi
 fv = 60.20 psi < Fvx' = 331.25 psi  (CSI = 0.18)   ➜  OK
12/1/2020 5
ΔLL = = 0.77 in.
(L/d)LL = 255.50 / 0.77 = 332
 ΔLL = 0.77 in = L/332 < L/180   ➜  OK
ΔTL = = 1.43 in.
(L/d)TL = 255.50 / 1.43 = 178
 ΔTL = 1.43 in = L/178 < L/120   ➜  OK
Ab = b x lb = 5.5 x 3.5 = 19.25 in2
fc⊥ = = 104.6 psi
 fc⊥ = 104.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.16)   ➜  OK
12/1/2020 6
