Beam Design - 1151 McClellan Beam Design
Design Span (L): 11.50 ft.
Clear Span: 11.00 ft.
Live Load: 9600 lbs
Dead Load: 3000 lbs
Selfweight: 75.8 lbs
Dist. Selfweight: 6.59 plf
Total Weight: 79.1 lbs
Beam Design Marc Fonger 278 Springfield Parkway 2011A
11/19/2020 1
11/19/2020 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (138.00 + 6)] x (12 in./ft.)3 = 2.31 ft3
Volumespan = N[A x L] = 2 x [13.88 x 138.00] x (12 in./ft.)3 = 2.22 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.31 = 79.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.22 = 75.8 lbs
9600 lbs
3000 lbs
ws = 6.59 plf
11.00 ft.
6339.55 lbs
6339.55 lbs
11/19/2020 3
fb = = 10191.6 psi
 fb = 10191.6 psi > Fbx' = 1138.5 psi  (CSI = 8.95)   ➜  NG
11/19/2020 4
fv* = = 342.31 psi
 fv* = 342.31 psi > Fvx' = 207.00 psi  (CSI = 1.65)   ➜  NG
fv = = 342.59 psi
 fv = 342.59 psi > Fvx' = 207.00 psi  (CSI = 1.66)   ➜  NG
11/19/2020 5
ΔLL =   =   = 1.66 in.
(L/d)LL = 138.00 / 1.66 = 83
 ΔLL = 1.66 in = L/83 > L/360   ➜  NG
ΔTL =   =   = 2.19 in.
(L/d)TL = 138.00 / 2.19 = 63
 ΔTL = 2.19 in = L/63 > L/240   ➜  NG
fc⊥ = = 352.2 psi
 fc⊥ = 352.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.56)   ➜  OK
11/19/2020 6
