Beam Design - Jim Holt - 3
Size: 3.125 x 13.5
Design Span (L): 31.75 ft.
Clear Span: 31.50 ft.
Total Span: 32.00 ft.
Live Load: 0 plf
Dead Load: 60 plf
Selfweight: 314.0 lbs
Dist. Selfweight: 9.89 plf
Total Weight: 316.5 lbs
Load Duration: 1.25
Notes: version 3
CV Volume Factor 0.996b - - - - -
Beam Design Jim Holt 42335
11/16/2020 1
b = 3.125 in.
d = 13.500 in.
A = 3.125 x 13.500 = 42.19 in.2
Sx = (3.125)(13.500)2/6 = 94.92 in.3
Sy = (3.125)2(13.500)/6 = 21.97 in.3
Ix = (3.125)(13.500)3/12 = 640.72 in.4
Iy = (3.125)3(13.500)/12 = 34.33 in.4
11/16/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [42.19 x (381.00 + 3)] x (12 in./ft.)3 = 9.38 ft3
Volumespan = N[A x L] = 1 x [42.19 x 381.00] x (12 in./ft.)3 = 9.30 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 9.38 = 316.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 9.30 = 314.0 lbs
0 plf
60 plf
  ws = 9.89 plf
31.75 ft.
31.50 ft.
32.00 ft.
1118.26 lbs
1118.26 lbs
11/16/2020 3
CV = = 0.996
CV = 0.996 < CL = 1
Fbx' = (2400)(0.9)(1)(1)(0.996) = 2152.1 psi
fb = = 1113.4 psi
 fb = 1113.4 psi < Fbx' = 2152.1 psi  (CSI = 0.52)   ➜  OK
11/16/2020 4
Fvx' = (265)(0.9)(1)(1) = 238.50 psi
fv* = = 36.65 psi
 fv* = 36.65 psi < Fvx' = 238.50 psi  (CSI = 0.15)   ➜  OK
fv = = 39.45 psi
 fv = 39.45 psi < Fvx' = 238.50 psi  (CSI = 0.17)   ➜  OK
11/16/2020 5
ΔLL = = 0.00 in.
(L/d)LL = 381.00 / 0.00 = ∞
ΔTL = = 1.39 in.
(L/d)TL = 381.00 / 1.39 = 275
 ΔTL = 1.39 in = L/275 < L/240   ➜  OK
fc⊥ = = 119.3 psi
 fc⊥ = 119.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.18)   ➜  OK
11/16/2020 6
