Beam Design - Jim Holt - 2
Size: 2.5 x 13.5
Design Span (L): 31.75 ft.
Clear Span: 31.50 ft.
Total Span: 32.00 ft.
Live Load: 0 plf
Selfweight: 251.2 lbs
Dist. Selfweight: 7.91 plf
Total Weight: 253.2 lbs
Load Duration: 1.25
Notes: Version 2
Beam Design Jim Holt Salt Lake City 42335
11/16/2020 1
b = 2.500 in.
d = 13.500 in.
A = 2.500 x 13.500 = 33.75 in.2
Sx = (2.500)(13.500)2/6 = 75.94 in.3
Sy = (2.500)2(13.500)/6 = 14.06 in.3
Ix = (2.500)(13.500)3/12 = 512.58 in.4
Iy = (2.500)3(13.500)/12 = 17.58 in.4
11/16/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [33.75 x (381.00 + 3)] x (12 in./ft.)3 = 7.50 ft3
Volumespan = N[A x L] = 1 x [33.75 x 381.00] x (12 in./ft.)3 = 7.44 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 7.50 = 253.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 7.44 = 251.2 lbs
Distributed Self Weight (ws) = = 7.91 plf
0 plf
  ws = 7.91 plf
31.75 ft.
31.50 ft.
32.00 ft.
1326.60 lbs
1326.60 lbs
11/16/2020 3
Fbx' = (2400)(0.9)(1)(1)(1.0) = 2160.0 psi
fb = = 1651.0 psi
 fb = 1651.0 psi < Fbx' = 2160.0 psi  (CSI = 0.76)   ➜  OK
11/16/2020 4
Fvx' = (265)(0.9)(1)(1) = 238.50 psi
fv* = = 54.35 psi
 fv* = 54.35 psi < Fvx' = 238.50 psi  (CSI = 0.23)   ➜  OK
fv = = 58.50 psi
 fv = 58.50 psi < Fvx' = 238.50 psi  (CSI = 0.25)   ➜  OK
11/16/2020 5
ΔLL = = 0.00 in.
(L/d)LL = 381.00 / 0.00 = ∞
ΔTL = = 2.05 in.
(L/d)TL = 381.00 / 2.05 = 185
 ΔTL = 2.05 in = L/185 > L/240   ➜  NG
fc⊥ = = 176.9 psi
 fc⊥ = 176.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.27)   ➜  OK
11/16/2020 6
