Grade: SPF SS
Design Span (L): 11.88 ft.
Clear Span: 11.63 ft.
Total Span: 12.13 ft.
Live Load: 128.8 plf
Dead Load: 19.2 plf
Selfweight: 33.3 lbs
Dist. Selfweight: 2.80 plf
Total Weight: 34.0 lbs
Beam Design Dominic Fontana Brew2x10x24
10/28/2020 1
10/28/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (142.50 + 3)] x (12 in./ft.)3 = 1.17 ft3
Volumespan = N[A x L] = 1 x [13.88 x 142.50] x (12 in./ft.)3 = 1.14 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.17 = 34.0 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.14 = 33.3 lbs
Distributed Self Weight (ws) = = 2.80 plf
128.8 plf
19.2 plf
ws = 2.80 plf
11.88 ft.
11.63 ft.
12.13 ft.
914.25 lbs
914.25 lbs
10/28/2020 3
Fbx' = (1250)(1.15)(1)(1)(1)(1.1)(1)(1.15) = 1818.4 psi
fb = = 1491.2 psi
 fb = 1491.2 psi < Fbx' = 1818.4 psi  (CSI = 0.82)   ➜  OK
10/28/2020 4
fv* = = 84.23 psi
 fv* = 84.23 psi < Fvx' = 155.25 psi  (CSI = 0.54)   ➜  OK
fv = = 96.80 psi
 fv = 96.80 psi < Fvx' = 155.25 psi  (CSI = 0.62)   ➜  OK
10/28/2020 5
ΔLL = = 0.39 in.
(L/d)LL = 142.50 / 0.39 = 367
 ΔLL = 0.39 in = L/367 < L/360   ➜  OK
ΔTL = = 0.45 in.
(L/d)TL = 142.50 / 0.45 = 313
 ΔTL = 0.45 in = L/313 < L/240   ➜  OK
fc⊥ = = 203.2 psi
 fc⊥ = 203.2 psi < Fc⊥x' = 425.00 psi  (CSI = 0.48)   ➜  OK
10/28/2020 6
