Species: Hem-Fir
Grade: HF SS
Design Span (L): 8.50 ft.
Clear Span: 8.00 ft.
Total Span: 9.00 ft.
Quantity (N): 4
Live Load: 542 plf
Dead Load: 95 plf
Selfweight: 118.5 lbs
Dist. Selfweight: 13.94 plf
Total Weight: 125.5 lbs
Beam Design 2020A225
10/28/2020 1
G = 0.43
10/28/2020 2
= 29.74 lbs/ft3
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (102.00 + 6)] x (12 in./ft.)3 = 4.22 ft3
Volumespan = N[A x L] = 4 x [16.88 x 102.00] x (12 in./ft.)3 = 3.98 ft3
Total Weight (WT) = ρw x Volumetotal = 29.74 x 4.22 = 125.5 lbs
Self Weight (WS) = ρw x Volumespan = 29.74 x 3.98 = 118.5 lbs
Distributed Self Weight (ws) = = 13.94 plf
542 plf
95 plf
ws = 13.94 plf
8.50 ft.
9.00 ft.
2929.24 lbs
2929.24 lbs
10/28/2020 3
lu = Unbraced Length = 8.5 ft.
lu/d = = 9.07
le = 1.63lu + 3d = 1.63(102.0) + 3(11.25) = 200.01 in. = 16.67 ft.  (NDS Table 3.3.3)
Rb = = 7.91
 Rb = 7.91 < 50   ➜  OK
10/28/2020 4
FbE = = 11135.44 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1400)(1.00)(1)(1)(1)(1)(1) = 1400.00 psi
CL =   = 0.993
Fbx' = (1400)(1.00)(1)(1)(0.993)(1)(1)(1) = 1390.1 psi
fb = = 557.4 psi
 fb = 557.4 psi < Fbx' = 1390.1 psi  (CSI = 0.40)   ➜  OK
Fvx' = (150)(1.00)(1)(1)(1) = 150.00 psi
fv* = = 47.92 psi
 fv* = 47.92 psi < Fvx' = 150.00 psi  (CSI = 0.32)   ➜  OK
fv = = 61.48 psi
 fv = 61.48 psi < Fvx' = 150.00 psi  (CSI = 0.41)   ➜  OK
10/28/2020 5
ΔLL = = 0.06 in.
(L/d)LL = 102.00 / 0.06 = 1825
 ΔLL = 0.06 in = L/1825 < L/360   ➜  OK
ΔTL = = 0.07 in.
(L/d)TL = 102.00 / 0.07 = 1520
 ΔTL = 0.07 in = L/1520 < L/240   ➜  OK
fc⊥ = = 81.4 psi
 fc⊥ = 81.4 psi < Fc⊥x' = 405.00 psi  (CSI = 0.20)   ➜  OK
10/28/2020 6
