Species: Hem-Fir
Grade: HF SS
Design Span (L): 17.00 ft.
Clear Span: 16.50 ft.
Total Span: 17.50 ft.
Quantity (N): 5
Live Load: 408 plf
Dead Load: 76 plf
Selfweight: 296.3 lbs
Dist. Selfweight: 17.43 plf
Total Weight: 305.0 lbs
Beam Design 2020A222
10/28/2020 1
G = 0.43
10/28/2020 2
= 29.74 lbs/ft3
Volumetotal = N[A x (L + lb)] = 5 x [16.88 x (204.00 + 6)] x (12 in./ft.)3 = 10.25 ft3
Volumespan = N[A x L] = 5 x [16.88 x 204.00] x (12 in./ft.)3 = 9.96 ft3
Total Weight (WT) = ρw x Volumetotal = 29.74 x 10.25 = 305.0 lbs
Self Weight (WS) = ρw x Volumespan = 29.74 x 9.96 = 296.3 lbs
Distributed Self Weight (ws) = = 17.43 plf
408 plf
76 plf
ws = 17.43 plf
17.00 ft.
16.50 ft.
17.50 ft.
4387.49 lbs
4387.49 lbs
10/28/2020 3
lu = Unbraced Length = 17 ft.
lu/d = = 18.13
le = 1.63lu + 3d = 1.63(204.0) + 3(11.25) = 366.27 in. = 30.52 ft.  (NDS Table 3.3.3)
Rb = = 8.56
 Rb = 8.56 < 50   ➜  OK
10/28/2020 4
FbE = = 9501.19 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1400)(1.00)(1)(1)(1)(1)(1) = 1400.00 psi
CL =   = 0.992
Fbx' = (1400)(1.00)(1)(1)(0.992)(1)(1)(1) = 1388.1 psi
fb = = 1374.0 psi
 fb = 1374.0 psi < Fbx' = 1388.1 psi  (CSI = 0.99)   ➜  OK
Fvx' = (150)(1.00)(1)(1)(1) = 150.00 psi
fv* = = 67.41 psi
 fv* = 67.41 psi < Fvx' = 150.00 psi  (CSI = 0.45)   ➜  OK
fv = = 75.77 psi
 fv = 75.77 psi < Fvx' = 150.00 psi  (CSI = 0.51)   ➜  OK
10/28/2020 5
ΔLL = = 0.54 in.
(L/d)LL = 204.00 / 0.54 = 379
 ΔLL = 0.54 in = L/379 < L/360   ➜  OK
ΔTL = = 0.66 in.
(L/d)TL = 204.00 / 0.66 = 308
 ΔTL = 0.66 in = L/308 < L/240   ➜  OK
fc⊥ = = 97.5 psi
 fc⊥ = 97.5 psi < Fc⊥x' = 405.00 psi  (CSI = 0.24)   ➜  OK
10/28/2020 6
