Beam Design - d
Grade: SPF SS
Design Span (L): 14.45 ft.
Clear Span: 14.20 ft.
Total Span: 14.70 ft.
Live Load: 86 plf
Dead Load: 9 plf
Selfweight: 31.8 lbs
Dist. Selfweight: 2.20 plf
Total Weight: 32.3 lbs
Beam Design f sl SL Brew2
10/27/2020 1
10/27/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (173.40 + 3)] x (12 in./ft.)3 = 1.11 ft3
Volumespan = N[A x L] = 1 x [10.88 x 173.40] x (12 in./ft.)3 = 1.09 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.11 = 32.3 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.09 = 31.8 lbs
Distributed Self Weight (ws) = = 2.20 plf
86 plf
9 plf
ws = 2.20 plf
14.45 ft.
14.20 ft.
14.70 ft.
714.40 lbs
714.40 lbs
10/27/2020 3
Fbx' = (1250)(1.15)(1)(1)(1)(1.2)(1)(1.15) = 1983.7 psi
fb = = 2316.7 psi
 fb = 2316.7 psi > Fbx' = 1983.7 psi  (CSI = 1.17)   ➜  NG
10/27/2020 4
fv* = = 88.76 psi
 fv* = 88.76 psi < Fvx' = 155.25 psi  (CSI = 0.57)   ➜  OK
fv = = 96.86 psi
 fv = 96.86 psi < Fvx' = 155.25 psi  (CSI = 0.62)   ➜  OK
10/27/2020 5
ΔLL = = 1.18 in.
(L/d)LL = 173.40 / 1.18 = 147
 ΔLL = 1.18 in = L/147 > L/360   ➜  NG
ΔTL = = 1.33 in.
(L/d)TL = 173.40 / 1.33 = 130
 ΔTL = 1.33 in = L/130 > L/240   ➜  NG
fc⊥ = = 158.8 psi
 fc⊥ = 158.8 psi < Fc⊥x' = 425.00 psi  (CSI = 0.37)   ➜  OK
10/27/2020 6
