Beam Design - rafter
Grade: SPF SS
Design Span (L): 12.75 ft.
Clear Span: 12.50 ft.
Total Span: 13.00 ft.
Live Load: 78 plf
Dead Load: 12 plf
Selfweight: 28.0 lbs
Dist. Selfweight: 2.20 plf
Total Weight: 28.6 lbs
Beam Design d f sl SL Brew
10/26/2020 1
10/26/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (153.00 + 3)] x (12 in./ft.)3 = 0.98 ft3
Volumespan = N[A x L] = 1 x [10.88 x 153.00] x (12 in./ft.)3 = 0.96 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.98 = 28.6 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.96 = 28.0 lbs
Distributed Self Weight (ws) = = 2.20 plf
78 plf
12 plf
ws = 2.20 plf
12.75 ft.
12.50 ft.
13.00 ft.
599.28 lbs
599.28 lbs
10/26/2020 3
Fbx' = (1250)(1.15)(1)(1)(1)(1.2)(1)(1) = 1725.0 psi
fb = = 1710.9 psi
 fb = 1710.9 psi < Fbx' = 1725.0 psi  (CSI = 0.99)   ➜  OK
10/26/2020 4
fv* = = 73.39 psi
 fv* = 73.39 psi < Fvx' = 155.25 psi  (CSI = 0.47)   ➜  OK
fv = = 81.07 psi
 fv = 81.07 psi < Fvx' = 155.25 psi  (CSI = 0.52)   ➜  OK
10/26/2020 5
ΔLL = = 0.65 in.
(L/d)LL = 153.00 / 0.65 = 236
 ΔLL = 0.65 in = L/236 < L/180   ➜  OK
ΔTL = = 0.77 in.
(L/d)TL = 153.00 / 0.77 = 199
 ΔTL = 0.77 in = L/199 < L/120   ➜  OK
fc⊥ = = 133.2 psi
 fc⊥ = 133.2 psi < Fc⊥x' = 425.00 psi  (CSI = 0.31)   ➜  OK
10/26/2020 6
