Grade: DF SS
Design Span (L): 16.50 ft.
Clear Span: 16.25 ft.
Total Span: 16.75 ft.
Quantity (N): 4
Live Load: 353 plf
Dead Load: 68 plf
Selfweight: 264.5 lbs
Dist. Selfweight: 16.03 plf
Total Weight: 268.6 lbs
CL Beam Stability Factor 0.988 - - - - -
Beam Design 2020A219
10/25/2020 1
10/25/2020 2
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (198.00 + 3)] x (12 in./ft.)3 = 7.85 ft3
Volumespan = N[A x L] = 4 x [16.88 x 198.00] x (12 in./ft.)3 = 7.73 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 7.85 = 268.6 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 7.73 = 264.5 lbs
353 plf
68 plf
ws = 16.03 plf
16.50 ft.
16.25 ft.
16.75 ft.
3660.15 lbs
3660.15 lbs
10/25/2020 3
lu = Unbraced Length = 16.5 ft.
lu/d = = 17.60
le = 1.63lu + 3d = 1.63(198.0) + 3(11.25) = 356.49 in. = 29.71 ft.  (NDS Table 3.3.3)
Rb = = 10.55
 Rb = 10.55 < 50   ➜  OK
10/25/2020 4
FbE = = 7432.47 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1500)(1.00)(1)(1)(1)(1)(1) = 1500.00 psi
CL =   = 0.988
Fbx' = (1500)(1.00)(1)(1)(0.988)(1)(1)(1) = 1481.6 psi
fb = = 1410.2 psi
 fb = 1410.2 psi < Fbx' = 1481.6 psi  (CSI = 0.95)   ➜  OK
fv* = = 71.02 psi
 fv* = 71.02 psi < Fvx' = 180.00 psi  (CSI = 0.39)   ➜  OK
fv = = 80.12 psi
 fv = 80.12 psi < Fvx' = 180.00 psi  (CSI = 0.45)   ➜  OK
10/25/2020 5
ΔLL = = 0.44 in.
(L/d)LL = 198.00 / 0.44 = 455
 ΔLL = 0.44 in = L/455 < L/360   ➜  OK
ΔTL = = 0.54 in.
(L/d)TL = 198.00 / 0.54 = 367
 ΔTL = 0.54 in = L/367 < L/240   ➜  OK
fc⊥ = = 203.3 psi
 fc⊥ = 203.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.33)   ➜  OK
10/25/2020 6
