Species: Hem-Fir
Grade: HF SS
Design Span (L): 16.50 ft.
Clear Span: 16.25 ft.
Total Span: 16.75 ft.
Quantity (N): 4
Live Load: 334 plf
Dead Load: 65 plf
Selfweight: 230.0 lbs
Dist. Selfweight: 13.94 plf
Total Weight: 233.5 lbs
Beam Design 2020A218
10/25/2020 1
G = 0.43
10/25/2020 2
= 29.74 lbs/ft3
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (198.00 + 3)] x (12 in./ft.)3 = 7.85 ft3
Volumespan = N[A x L] = 4 x [16.88 x 198.00] x (12 in./ft.)3 = 7.73 ft3
Total Weight (WT) = ρw x Volumetotal = 29.74 x 7.85 = 233.5 lbs
Self Weight (WS) = ρw x Volumespan = 29.74 x 7.73 = 230.0 lbs
Distributed Self Weight (ws) = = 13.94 plf
334 plf
65 plf
ws = 13.94 plf
16.50 ft.
16.25 ft.
16.75 ft.
3458.39 lbs
3458.39 lbs
10/25/2020 3
Fbx' = (1400)(1.00)(1)(1)(1)(1)(1)(1) = 1400.0 psi
fb = = 1332.4 psi
 fb = 1332.4 psi < Fbx' = 1400.0 psi  (CSI = 0.95)   ➜  OK
10/25/2020 4
Fvx' = (150)(1.00)(1)(1)(1) = 150.00 psi
fv* = = 67.10 psi
 fv* = 67.10 psi < Fvx' = 150.00 psi  (CSI = 0.45)   ➜  OK
fv = = 75.71 psi
 fv = 75.71 psi < Fvx' = 150.00 psi  (CSI = 0.50)   ➜  OK
10/25/2020 5
ΔLL = = 0.49 in.
(L/d)LL = 198.00 / 0.49 = 405
 ΔLL = 0.49 in = L/405 < L/360   ➜  OK
ΔTL = = 0.60 in.
(L/d)TL = 198.00 / 0.60 = 327
 ΔTL = 0.60 in = L/327 < L/240   ➜  OK
fc⊥ = = 192.1 psi
 fc⊥ = 192.1 psi < Fc⊥x' = 405.00 psi  (CSI = 0.47)   ➜  OK
10/25/2020 6
