Grade: DF SS
Design Span (L): 16.50 ft.
Clear Span: 16.25 ft.
Total Span: 16.75 ft.
Quantity (N): 4
Live Load: 373 plf
Dead Load: 72 plf
Selfweight: 264.5 lbs
Dist. Selfweight: 16.03 plf
Total Weight: 268.6 lbs
Beam Design 2020A217
10/25/2020 1
10/25/2020 2
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (198.00 + 3)] x (12 in./ft.)3 = 7.85 ft3
Volumespan = N[A x L] = 4 x [16.88 x 198.00] x (12 in./ft.)3 = 7.73 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 7.85 = 268.6 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 7.73 = 264.5 lbs
373 plf
72 plf
ws = 16.03 plf
16.50 ft.
16.25 ft.
16.75 ft.
3861.15 lbs
3861.15 lbs
10/25/2020 3
Fbx' = (1500)(1.00)(1)(1)(1)(1)(1)(1) = 1500.0 psi
fb = = 1487.6 psi
 fb = 1487.6 psi < Fbx' = 1500.0 psi  (CSI = 0.99)   ➜  OK
10/25/2020 4
fv* = = 74.92 psi
 fv* = 74.92 psi < Fvx' = 180.00 psi  (CSI = 0.42)   ➜  OK
fv = = 84.52 psi
 fv = 84.52 psi < Fvx' = 180.00 psi  (CSI = 0.47)   ➜  OK
10/25/2020 5
ΔLL = = 0.46 in.
(L/d)LL = 198.00 / 0.46 = 431
 ΔLL = 0.46 in = L/431 < L/360   ➜  OK
ΔTL = = 0.57 in.
(L/d)TL = 198.00 / 0.57 = 348
 ΔTL = 0.57 in = L/348 < L/240   ➜  OK
fc⊥ = = 214.5 psi
 fc⊥ = 214.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.34)   ➜  OK
10/25/2020 6
