Design Span (L): 4.75 ft.
Clear Span: 4.50 ft.
Total Span: 5.00 ft.
Live Load: 25 plf
Dead Load: 15 plf
Selfweight: 12.3 lbs
Dist. Selfweight: 2.58 plf
Total Weight: 12.9 lbs
Orientation: Horizontal
Beam Design 2020A214
10/25/2020 1
10/25/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (57.00 + 3)] x (12 in./ft.)3 = 0.38 ft3
Volumespan = N[A x L] = 1 x [10.88 x 57.00] x (12 in./ft.)3 = 0.36 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.38 = 12.9 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.36 = 12.3 lbs
25 plf
15 plf
ws = 2.58 plf
4.75 ft.
4.50 ft.
5.00 ft.
106.46 lbs
106.46 lbs
10/25/2020 3
Fby' = (900)(1.15)(1)(1)(1)(1.2)(1.15)(1)(1) = 1428.3 psi
fb = = 530.1 psi
 fb = 530.1 psi < Fby' = 1428.3 psi  (CSI = 0.37)   ➜  OK
10/25/2020 4
fv* = = 13.22 psi
 fv* = 13.22 psi < Fvy' = 207.00 psi  (CSI = 0.06)   ➜  OK
fv = = 13.95 psi
 fv = 13.95 psi < Fvy' = 207.00 psi  (CSI = 0.07)   ➜  OK
10/25/2020 5
ΔLL = = 0.09 in.
(L/d)LL = 57.00 / 0.09 = 649
 ΔLL = 0.09 in = L/649 < L/180   ➜  OK
ΔTL = = 0.15 in.
(L/d)TL = 57.00 / 0.15 = 381
 ΔTL = 0.15 in = L/381 < L/120   ➜  OK
Ab = d x lb = 7.25 x 3 = 21.75 in2
fc⊥ = = 4.9 psi
 fc⊥ = 4.9 psi < Fc⊥y' = 625.00 psi  (CSI = 0.01)   ➜  OK
10/25/2020 6
