Size: 5.5 x 16.5
Design Span (L): 29.25 ft.
Clear Span: 29.00 ft.
Total Span: 29.50 ft.
Live Load: 170 plf
Dead Load: 100 plf
Selfweight: 622.3 lbs
Dist. Selfweight: 21.28 plf
Total Weight: 627.7 lbs
CV Volume Factor 0.930b - - - - -
Beam Design 2020A213
10/19/2020 1
d = 16.500 in.
10/19/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [90.75 x (351.00 + 3)] x (12 in./ft.)3 = 18.59 ft3
Volumespan = N[A x L] = 1 x [90.75 x 351.00] x (12 in./ft.)3 = 18.43 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 18.59 = 627.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 18.43 = 622.3 lbs
170 plf
  ws = 21.28 plf
29.25 ft.
29.00 ft.
29.50 ft.
4296.33 lbs
4296.33 lbs
10/19/2020 3
CV = = 0.930
CV = 0.930 < CL = 1
Fbx' = (2400)(1.00)(1)(0.8)(0.930) = 1786.5 psi
fb = = 1497.9 psi
 fb = 1497.9 psi < Fbx' = 1786.5 psi  (CSI = 0.84)   ➜  OK
10/19/2020 4
Fvx' = (265)(1.00)(1)(0.8) = 212.00 psi
fv* = = 63.79 psi
 fv* = 63.79 psi < Fvx' = 212.00 psi  (CSI = 0.30)   ➜  OK
fv = = 70.41 psi
 fv = 70.41 psi < Fvx' = 212.00 psi  (CSI = 0.33)   ➜  OK
10/19/2020 5
ΔLL = = 0.84 in.
(L/d)LL = 351.00 / 0.84 = 418
 ΔLL = 0.84 in = L/418 < L/360   ➜  OK
ΔTL = = 1.44 in.
(L/d)TL = 351.00 / 1.44 = 244
 ΔTL = 1.44 in = L/244 < L/240   ➜  OK
fc⊥ = = 260.4 psi
 fc⊥ = 260.4 psi < Fc⊥x' = 520.00 psi  (CSI = 0.50)   ➜  OK
10/19/2020 6
