Design Span (L): 8.75 ft.
Clear Span: 8.50 ft.
Total Span: 9.00 ft.
Live Load: 258 plf
Dead Load: 132 plf
Selfweight: 57.7 lbs
Dist. Selfweight: 6.59 plf
Total Weight: 59.3 lbs
Beam Design 2020A21
2/14/2020 1
Beam Design 2020A21
2/14/2020 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (105.00 + 3)] x (12 in./ft.)3 = 1.73 ft3
Volumespan = N[A x L] = 2 x [13.88 x 105.00] x (12 in./ft.)3 = 1.69 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.73 = 59.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.69 = 57.7 lbs
258 plf
132 plf
ws = 6.59 plf
8.75 ft.
8.50 ft.
9.00 ft.
1784.66 lbs
1784.66 lbs
Beam Design 2020A21
2/14/2020 3
fb = = 1064.6 psi
 fb = 1064.6 psi < Fbx' = 1138.5 psi  (CSI = 0.94)   ➜  OK
Beam Design 2020A21
2/14/2020 4
fv* = = 77.26 psi
 fv* = 77.26 psi < Fvx' = 207.00 psi  (CSI = 0.37)   ➜  OK
fv = = 93.79 psi
 fv = 93.79 psi < Fvx' = 207.00 psi  (CSI = 0.45)   ➜  OK
Beam Design 2020A21
2/14/2020 5
ΔLL = = 0.11 in.
(L/d)LL = 105.00 / 0.11 = 977
 ΔLL = 0.11 in = L/977 < L/360   ➜  OK
ΔTL = = 0.17 in.
(L/d)TL = 105.00 / 0.17 = 636
 ΔTL = 0.17 in = L/636 < L/240   ➜  OK
fc⊥ = = 198.3 psi
 fc⊥ = 198.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.32)   ➜  OK
Beam Design 2020A21
2/14/2020 6
